DBPOWER RD-810 Imager Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
10
Past 30 Days:
59
All Time:
973
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
The imager creates the picture that the projector displays. Because any dust or dirt stuck to the imager could cause distortions, it is important to keep the imager clean. If the image is not being displayed or is blurry or distorted, the imager may need to be cleaned or replaced.
    1. DBPOWER RD-810 Imager Replacement, Top Cover: step 1, image 1 of 2 DBPOWER RD-810 Imager Replacement, Top Cover: step 1, image 2 of 2
      • Make sure the projector is unplugged before starting
      • Place the projector upside down to access the screws on the bottom.
      • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
      Ask FixBot
    2. DBPOWER RD-810 Imager Replacement: step 2, image 1 of 1
      • Flip the projector over and then remove the cover by lifting it up.
      Ask FixBot
    1. DBPOWER RD-810 Imager Replacement, Motherboard and LED Bulb: step 3, image 1 of 3 DBPOWER RD-810 Imager Replacement, Motherboard and LED Bulb: step 3, image 2 of 3 DBPOWER RD-810 Imager Replacement, Motherboard and LED Bulb: step 3, image 3 of 3
      • Remove the three 6mm PH2 phillips head screws.
      • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
      Ask FixBot
    2. DBPOWER RD-810 Imager Replacement: step 4, image 1 of 3 DBPOWER RD-810 Imager Replacement: step 4, image 2 of 3 DBPOWER RD-810 Imager Replacement: step 4, image 3 of 3
      • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
      • Keep the connector parallel to the mother board to avoid breaking the solder connection.
      • Lift the motherboard up and place it out of the way.
      Ask FixBot
    3. DBPOWER RD-810 Imager Replacement: step 5, image 1 of 3 DBPOWER RD-810 Imager Replacement: step 5, image 2 of 3 DBPOWER RD-810 Imager Replacement: step 5, image 3 of 3
      • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
      • Lift the aluminum heat sink up to remove it from the projector.
      • The motherboard is already removed in this step.
      Ask FixBot
    1. DBPOWER RD-810 Imager Replacement, Imager: step 6, image 1 of 1
      • Lift the imager straight up to remove it from the projector.
      Ask FixBot
2 other people completed this guide.
John Russell
941 Reputation
9 Guides authored
USF Tampa, Team S5-G3, Eyestone Spring 2018 Member of USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 59
All Time: 973
