Up to 20% off select tools
D-Link dir-645 Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
79
All Time:
974
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
    1. D-Link dir-645 Disassembly, Pry off the top: step 1, image 1 of 1
      • Pry off the top using a plastic pryer
      Ask FixBot
    2. D-Link dir-645 Disassembly, Unscrew the bottom screws: step 2, image 1 of 1
      • Bottom: unscrew the two philips screws . Note: this probably voids any warranty
      Ask FixBot
    3. D-Link dir-645 Disassembly, Pry off the bottom: step 3, image 1 of 1
      • Carefully pry off the bottom plastic
      Ask FixBot
    4. D-Link dir-645 Disassembly, Split the cylinder in half: step 4, image 1 of 2 D-Link dir-645 Disassembly, Split the cylinder in half: step 4, image 2 of 2
      • Start to pry at the bottom.
      • Work your way around until it comes off.
      Ask FixBot
    5. D-Link dir-645 Disassembly, Opened!: step 5, image 1 of 2 D-Link dir-645 Disassembly, Opened!: step 5, image 2 of 2
      • The inside consists of the main board ant the antenna, that's it.
      • The 360 deg antenna is connected to the main board with Hirose U.FL connectors and can be easily removed. https://en.wikipedia.org/wiki/Hirose_U.F...
      Ask FixBot
2 other people completed this guide.
Author
with
Endorph
2,457 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 79
All Time: 974
