D-Link DIR-890L Power Switch Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
92
All Time:
1,662
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The power switch is the black button on the back of the router. If it is not pressing and appears to be broken, this guide will walk you through on the replacement of this switch.
Tools
    1. D-Link DIR-890L Power Switch Replacement, Case: step 1, image 1 of 3 D-Link DIR-890L Power Switch Replacement, Case: step 1, image 2 of 3 D-Link DIR-890L Power Switch Replacement, Case: step 1, image 3 of 3
      • Peel off the four rubber rectangular feet with your fingers.
      • The feet may be hard to remove. Apply additional force if necessary.
      Ask FixBot
    2. D-Link DIR-890L Power Switch Replacement: step 2, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 2, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 2, image 3 of 3
      • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
      Ask FixBot
    3. D-Link DIR-890L Power Switch Replacement: step 3, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 3, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 3, image 3 of 3
      • Wedge the opening tool between the red top panel and the gray bottom panel.
      • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
      Ask FixBot
    1. D-Link DIR-890L Power Switch Replacement, Motherboard: step 4, image 1 of 1
      • Orient the router so the narrow end of the router faces you and the ports face away from you.
      • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
      Ask FixBot
    2. D-Link DIR-890L Power Switch Replacement: step 5, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 5, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 5, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
    3. D-Link DIR-890L Power Switch Replacement: step 6, image 1 of 2 D-Link DIR-890L Power Switch Replacement: step 6, image 2 of 2
      • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
      Ask FixBot
    4. D-Link DIR-890L Power Switch Replacement: step 7, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 7, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 7, image 3 of 3
      • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
      Ask FixBot
    5. D-Link DIR-890L Power Switch Replacement: step 8, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 8, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 8, image 3 of 3
      • Pull the yellow tape off of the motherboard to release the final antenna wire.
      Ask FixBot
    6. D-Link DIR-890L Power Switch Replacement: step 9, image 1 of 2 D-Link DIR-890L Power Switch Replacement: step 9, image 2 of 2
      • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
      Ask FixBot
    1. D-Link DIR-890L Power Switch Replacement, Power Switch: step 10, image 1 of 3 D-Link DIR-890L Power Switch Replacement, Power Switch: step 10, image 2 of 3 D-Link DIR-890L Power Switch Replacement, Power Switch: step 10, image 3 of 3
      • Locate the power switch on the top left of the motherboard.
      • The power switch is the component that sticks out the furthest.
      • Turn the motherboard upside down.
      • Locate the 6 solder joints that connect the power switch to the motherboard. They are arranged in 2 columns of 3.
      Ask FixBot
    2. D-Link DIR-890L Power Switch Replacement: step 11, image 1 of 2 D-Link DIR-890L Power Switch Replacement: step 11, image 2 of 2
      Desoldering Pump
      $3.99
      Buy
      • Using a soldering iron and desoldering pump, desolder the power switch from the board.
      • For more information, see this guide on desoldering.
      Ask FixBot
Rachel Shaw
553 Reputation
5 Guides authored
Cal Poly, Team 10-7, Livingston Fall 2016 Member of Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 92
All Time: 1,662
