D-Link DIR-890L Power Adapter Port Replacement
    1. D-Link DIR-890L Power Adapter Port Replacement, Case: step 1, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement, Case: step 1, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement, Case: step 1, image 3 of 3
      • Peel off the four rubber rectangular feet with your fingers.
      • The feet may be hard to remove. Apply additional force if necessary.
      Ask FixBot
    2. D-Link DIR-890L Power Adapter Port Replacement: step 2, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 2, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 2, image 3 of 3
      • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
      Ask FixBot
    3. D-Link DIR-890L Power Adapter Port Replacement: step 3, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 3, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 3, image 3 of 3
      • Wedge the opening tool between the red top panel and the gray bottom panel.
      • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
      Ask FixBot
    1. D-Link DIR-890L Power Adapter Port Replacement, Motherboard: step 4, image 1 of 1
      • Orient the router so the narrow end of the router faces you and the ports face away from you.
      • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
      Ask FixBot
    2. D-Link DIR-890L Power Adapter Port Replacement: step 5, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 5, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 5, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
    3. D-Link DIR-890L Power Adapter Port Replacement: step 6, image 1 of 2 D-Link DIR-890L Power Adapter Port Replacement: step 6, image 2 of 2
      • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
      Ask FixBot
    4. D-Link DIR-890L Power Adapter Port Replacement: step 7, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 7, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 7, image 3 of 3
      • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
      Ask FixBot
    5. D-Link DIR-890L Power Adapter Port Replacement: step 8, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 8, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 8, image 3 of 3
      • Pull the yellow tape off of the motherboard to release the final antenna wire.
      Ask FixBot
    6. D-Link DIR-890L Power Adapter Port Replacement: step 9, image 1 of 2 D-Link DIR-890L Power Adapter Port Replacement: step 9, image 2 of 2
      • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
      Ask FixBot
    1. D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: step 10, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: step 10, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: step 10, image 3 of 3
      • Locate the power adapter port at the top left of the motherboard.
      • Flip the motherboard over.
      • Locate the 3 solder joints that connect the power adapter port to the motherboard.
      Ask FixBot
    2. D-Link DIR-890L Power Adapter Port Replacement: step 11, image 1 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 11, image 2 of 3 D-Link DIR-890L Power Adapter Port Replacement: step 11, image 3 of 3
      Desoldering Pump
      $3.99
      Buy
      • Using a soldering iron and desoldering pump, desolder the power adapter port from the board.
      • For more information, see this guide on desoldering
      Ask FixBot
Rachel Shaw
553 Reputation
5 Guides authored
Cal Poly, Team 10-7, Livingston Fall 2016 Member of Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Members
72 Guides authored
1 Guide Comment
What are the specifications of the power port if we would like to replace it?
Chad Altobelli - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 27
All Time: 977
