D-Link DIR-890L Heat Sink Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
92
All Time:
1,740
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 7 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The heat sink is responsible for regulating the heat flow and temperature control in your device. If your device is overheating and not cooling itself down properly, then the heat sink will need to be replaced. Follow this guide for the steps on how to replace the heat sink.
Tools
    1. D-Link DIR-890L Heat Sink Replacement, Case: step 1, image 1 of 3 D-Link DIR-890L Heat Sink Replacement, Case: step 1, image 2 of 3 D-Link DIR-890L Heat Sink Replacement, Case: step 1, image 3 of 3
      • Peel off the four rubber rectangular feet with your fingers.
      • The feet may be hard to remove. Apply additional force if necessary.
      Ask FixBot
    2. D-Link DIR-890L Heat Sink Replacement: step 2, image 1 of 3 D-Link DIR-890L Heat Sink Replacement: step 2, image 2 of 3 D-Link DIR-890L Heat Sink Replacement: step 2, image 3 of 3
      • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
      Ask FixBot
    3. D-Link DIR-890L Heat Sink Replacement: step 3, image 1 of 3 D-Link DIR-890L Heat Sink Replacement: step 3, image 2 of 3 D-Link DIR-890L Heat Sink Replacement: step 3, image 3 of 3
      • Wedge the opening tool between the red top panel and the gray bottom panel.
      • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
      Ask FixBot
    1. D-Link DIR-890L Heat Sink Replacement, Heat Sink: step 4, image 1 of 3 D-Link DIR-890L Heat Sink Replacement, Heat Sink: step 4, image 2 of 3 D-Link DIR-890L Heat Sink Replacement, Heat Sink: step 4, image 3 of 3
      • Unscrew the two 7mm screws with a Phillips #1 screwdriver.
      • Lift the heat sink off the metal plate with your fingers.
      Ask FixBot
Michael Hilomen
201 Reputation
1 Guide authored
Cal Poly, Team 10-7, Livingston Fall 2016 Member of Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 92
All Time: 1,740
