D-Link DCS-825L Antenna Replacement
  1. D-Link DCS-825L Antenna Replacement, Accent Ring: step 1, image 1 of 1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
    Ask FixBot
  2. D-Link DCS-825L Antenna Replacement: step 2, image 1 of 1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
    Ask FixBot
  3. D-Link DCS-825L Antenna Replacement: step 3, image 1 of 1
    • Replace your accent ring with whichever color you choose.
    Ask FixBot
  4. D-Link DCS-825L Antenna Replacement, Back Casing: step 4, image 1 of 2 D-Link DCS-825L Antenna Replacement, Back Casing: step 4, image 2 of 2
    • Remove one Phillips #2 screw from each side of the camera lens.
    Ask FixBot
  5. D-Link DCS-825L Antenna Replacement: step 5, image 1 of 3 D-Link DCS-825L Antenna Replacement: step 5, image 2 of 3 D-Link DCS-825L Antenna Replacement: step 5, image 3 of 3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
    Ask FixBot
  6. D-Link DCS-825L Antenna Replacement: step 6, image 1 of 2 D-Link DCS-825L Antenna Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
    Ask FixBot
  7. D-Link DCS-825L Antenna Replacement: step 7, image 1 of 3 D-Link DCS-825L Antenna Replacement: step 7, image 2 of 3 D-Link DCS-825L Antenna Replacement: step 7, image 3 of 3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
    Ask FixBot
  8. D-Link DCS-825L Antenna Replacement, Antenna: step 8, image 1 of 1
    • Once you have the back casing removed from the other half of the device, it should look like this with the antenna poking out.
    Ask FixBot
  9. D-Link DCS-825L Antenna Replacement: step 9, image 1 of 3 D-Link DCS-825L Antenna Replacement: step 9, image 2 of 3 D-Link DCS-825L Antenna Replacement: step 9, image 3 of 3
    Buy
    • There will be a light yellow rubber stopper that is holding the antenna in place.
    • With your tweezers, gently tug on the stopper to make it come out, or at least come loose.
    • If the stopper does not completely come out, use the round top of the antenna to push down on it.
    • You can do this simply by pulling the antenna as close to the back casing as possible, and then pushing down on it until the rubber stopper comes out completely.
    • After it has come out, it can either be taken off from the antenna and set aside, or it can be kept on.
    Ask FixBot
  10. D-Link DCS-825L Antenna Replacement: step 10, image 1 of 2 D-Link DCS-825L Antenna Replacement: step 10, image 2 of 2
    • Once the rubber stopper has been pushed out, you will now be able to easily pull the antenna out from the back casing.
    • After it has been removed, you are now able to replace the antenna of your Wi-Fi Baby Camera.
    Ask FixBot
Alexis Clopton
97 Reputation
1 Guide authored
USF Tampa, Team S1-G5, Leahy Fall 2018 Member of USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 33
All Time: 865
