D-Link DCS-5222L Lens Replacement
  1. D-Link DCS-5222L Lens Replacement, Lens: step 1, image 1 of 3 D-Link DCS-5222L Lens Replacement, Lens: step 1, image 2 of 3 D-Link DCS-5222L Lens Replacement, Lens: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the four rubber feet with tweezers to access the screws.
    • Remove all four 7mm screws by using a #1 Phillips screwdriver.
    • Then, with your hands, pull off the lower part of the camera body.
    Ask FixBot
  2. D-Link DCS-5222L Lens Replacement: step 2, image 1 of 3 D-Link DCS-5222L Lens Replacement: step 2, image 2 of 3 D-Link DCS-5222L Lens Replacement: step 2, image 3 of 3
    • On the base motherboard, there are five connecting cables. Disconnect all of them from the motherboard gently using safety tweezers.
    • Do not cut or damage the cables.
    • Disconnecting the antenna cable from motherboard is not necessary.
    Ask FixBot
  3. D-Link DCS-5222L Lens Replacement: step 3, image 1 of 3 D-Link DCS-5222L Lens Replacement: step 3, image 2 of 3 D-Link DCS-5222L Lens Replacement: step 3, image 3 of 3
    • Remove the two 7mm screws holding the motor using a #1 Phillips screwdriver.
    • Pull off the motor and lift away the midbody of the camera using your hands.
    Ask FixBot
  4. D-Link DCS-5222L Lens Replacement: step 4, image 1 of 2 D-Link DCS-5222L Lens Replacement: step 4, image 2 of 2
    • Separate the black camera shroud from the upper body by prying loose the tabs with a plastic opening tool or spudger.
    • Use your hands to wiggle the shroud free.
    Ask FixBot
  5. D-Link DCS-5222L Lens Replacement: step 5, image 1 of 3 D-Link DCS-5222L Lens Replacement: step 5, image 2 of 3 D-Link DCS-5222L Lens Replacement: step 5, image 3 of 3
    • Use a #1 Phillips screwdriver to unscrew the four 5mm screws on both sides of the black camera housing to separate it from white body.
    • Unscrew the two 7mm #1 Phillips screws on both sides of the camera housing to open it.
    Ask FixBot
  6. D-Link DCS-5222L Lens Replacement: step 6, image 1 of 3 D-Link DCS-5222L Lens Replacement: step 6, image 2 of 3 D-Link DCS-5222L Lens Replacement: step 6, image 3 of 3
    • Gently disconnect the three cables from the small motherboard using safety tweezers.
    • Use a #0 Phillips screwdriver to remove the two black 2mm screws and a #1 Phillips screwdriver to remove the 2 silver 6mm screws.
    • Separate the board from the black housing.
    Ask FixBot
  7. D-Link DCS-5222L Lens Replacement: step 7, image 1 of 3 D-Link DCS-5222L Lens Replacement: step 7, image 2 of 3 D-Link DCS-5222L Lens Replacement: step 7, image 3 of 3
    • Using your fingers, remove the focus adjustment ring.
    • Twist the lens to unscrew it from the camera module.
    • Replace the broken lens with new one and reassemble all parts of the camera respectively.
    Ask FixBot
Atefeh Rahmani
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,483
