D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: step 1, image 1 of 1
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
    Ask FixBot
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 2, image 1 of 1
    • Remove the back casing to expose the circuit board.
    Ask FixBot
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 3, image 1 of 1
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
    Ask FixBot
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 4, image 1 of 1
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
    Ask FixBot
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: step 5, image 1 of 1
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
    Ask FixBot
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 6, image 1 of 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 6, image 2 of 2
    • Detach the white plug by gently pulling on the black wires.
    Ask FixBot
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 7, image 1 of 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 7, image 2 of 2
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
    Ask FixBot
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 8, image 1 of 2 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 8, image 2 of 2
    • Gently pull on the grey wire to detach the microphone from the camera body.
    Ask FixBot
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 9, image 1 of 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 9, image 2 of 3 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: step 9, image 3 of 3
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
    Ask FixBot
IUPUI, Team S4-G2, Baechle Spring 2018 Member of IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 695
