D-Link HD Wi-Fi Camera Motherboard Replacement
  1. D-Link   HD Wi-Fi Camera Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
    Ask FixBot
  2. D-Link   HD Wi-Fi Camera Motherboard Replacement: step 2, image 1 of 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: step 2, image 2 of 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
    Ask FixBot
  3. D-Link   HD Wi-Fi Camera Motherboard Replacement: step 3, image 1 of 2 D-Link   HD Wi-Fi Camera Motherboard Replacement: step 3, image 2 of 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
    Ask FixBot
1 Guide Comment
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
Azlin Rahim - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 1,281
