Cyclone Range Hood (Model CY3000R) Circuit Board Replacement
  1. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement, Circuit Board: step 1, image 1 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement, Circuit Board: step 1, image 2 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement, Circuit Board: step 1, image 3 of 3
    • To avoid unforeseen electric shocks, turn off the fuse supplying power to your range hood to avoid the risk of electrocution.
    • Empty all of the grease from the grease container and clean it.
    Ask FixBot
  2. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 2, image 1 of 2 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 2, image 2 of 2
    • The panel will be loose after the screws and bulbs are removed; be sure to support the panel while removing the screws and bulbs.
    • Remove the five 10 mm Phillips #1 screws securing the panel while holding the panel in place.
    Ask FixBot
  3. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 3, image 1 of 2 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 3, image 2 of 2
    • Turn the LED bulbs counterclockwise and remove them.
    • Push the panel down to remove it from the body.
    Ask FixBot
  4. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 4, image 1 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 4, image 2 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 4, image 3 of 3
    • Carefully remove the four 5 mm Phillips #1 screws from the board box.
    • Open the lid.
    Ask FixBot
  5. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 5, image 1 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 5, image 2 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 5, image 3 of 3
    • Pull out the ten-pin white head cable located on the left side of the board.
    • Remove the cables one by one on the right side of the board.
    • Install the replacement board into the board box.
    Ask FixBot
  6. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 6, image 1 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 6, image 2 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 6, image 3 of 3
    • Insert the tips of the wires into the board's protective plastic that comes with your replacement board.
    • To reinsert the wires, insert the two black wires into the first two slots on the top.
    • The second row is for the white wires, which can be attached in any order; for the remaining red wires, adhere to the ordered numbers attached to the wires.
    Ask FixBot
  7. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 7, image 1 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 7, image 2 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 7, image 3 of 3
    • Replace the lid.
    • Reinstall the four 5 mm Phillips #1 screws to secure the lid.
    • Shut the panel.
    Ask FixBot
  8. Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 8, image 1 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 8, image 2 of 3 Cyclone Range Hood (Model CY3000R) Circuit Board Replacement: step 8, image 3 of 3
    • Set the panel in place, and secure all five 10 mm Phillips #1 screws to their respective locations while holding the panel.
    • Replace the LED bulbs.
    Ask FixBot
Enjoy your fully functional range.
Hesam Esmaeilianaraghi
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 903
