Up to 20% off select tools
CyberSeriesPC C-Series RAM Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
82
All Time:
5,509
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you want to upgrade the RAM in your prebuilt CyberSeriesPC (Model C-Series) so your computer can be faster, use this step-by-step guide to replace your RAM.
A RAM's purpose is to store the short-term data that a PC requires to operate correctly, so having an updated RAM will help optimize your computer.
Here's an article on why having better RAM is important.
Be careful with the electronic parts and RAM because they are delicate and could break.
Before beginning, make sure to power off your computer entirely and disconnect from any external power source. This is critical because if you do not do this, you can harm your computer and even yourself.
    1. CyberSeriesPC C-Series RAM Replacement, RAM: step 1, image 1 of 3 CyberSeriesPC C-Series RAM Replacement, RAM: step 1, image 2 of 3 CyberSeriesPC C-Series RAM Replacement, RAM: step 1, image 3 of 3
      • Before doing anything, you must be sure that the computer itself is off so no damage or loss of data can be made to the computer.
      • Turn the computer around and turn the power switch from "I" (on) to "O" (off).
      • Remove the power cable from its outlet and disconnect any peripherals (microphone, webcam, etc.).
      Ask FixBot
    2. CyberSeriesPC C-Series RAM Replacement: step 2, image 1 of 3 CyberSeriesPC C-Series RAM Replacement: step 2, image 2 of 3 CyberSeriesPC C-Series RAM Replacement: step 2, image 3 of 3
      • Place the computer on a table.
      • Remove the screws holding the side panel with a screwdriver.
      • Slide the side panel from right to left to open the computer and see its components.
      • Place the side panel somewhere else to keep the area clear, and set the computer down on its side, where the open side is up for you to work.
      • From here on out, you should have your flashlight to shine a light on your computer so you can see the components.
      Ask FixBot
    3. CyberSeriesPC C-Series RAM Replacement: step 3, image 1 of 3 CyberSeriesPC C-Series RAM Replacement: step 3, image 2 of 3 CyberSeriesPC C-Series RAM Replacement: step 3, image 3 of 3
      • Open the latches in front of the RAM using two fingers.
      • Place two fingers and your thumb down in the middle of the RAM stick and remove it carefully and slowly.
      • Repeat this step for both RAM sticks.
      Ask FixBot
    4. CyberSeriesPC C-Series RAM Replacement: step 4, image 1 of 3 CyberSeriesPC C-Series RAM Replacement: step 4, image 2 of 3 CyberSeriesPC C-Series RAM Replacement: step 4, image 3 of 3
      • Line up the middle gap in the new RAM stick with the notch in the computer.
      • Push the stick down to insert the RAM into its place.
      • When properly inserted, you will hear a click and the latch will automatically close to hold the RAM stick in place.
      • Repeat this step for the second stick.
      • When inserting the RAM, do not push down too hard. Considering the sticks are fragile, too much force can break the RAM stick.
      Ask FixBot
    5. CyberSeriesPC C-Series RAM Replacement: step 5, image 1 of 3 CyberSeriesPC C-Series RAM Replacement: step 5, image 2 of 3 CyberSeriesPC C-Series RAM Replacement: step 5, image 3 of 3
      • Slide the side panel back onto the computer from the left until it clicks.
      • Tighten the screws back onto the side panel with the screwdriver.
      • Before reinserting the power cable and turning the power switch on, insert any other removed wires.
      • Place the power cable back in its outlet.
      • Turn the power switch on.
      Ask FixBot
    6. CyberSeriesPC C-Series RAM Replacement: step 6, image 1 of 3 CyberSeriesPC C-Series RAM Replacement: step 6, image 2 of 3 CyberSeriesPC C-Series RAM Replacement: step 6, image 3 of 3
      • To confirm the RAM sticks are properly working, turn the computer on and let it boot up.
      • Click on the search button in the lower-left corner of your monitor screen.
      • Search for "System Information," then click on it.
      • In the "Find what:" search bar, type "RAM," and press enter.
      • You will see that your new RAM is installed correctly and working, making it a successful switching of parts!
      Ask FixBot
6 other people completed this guide.
Author
with
Jamie Lira
277 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 82
All Time: 5,509
