Up to 20% off select tools
CyberPowerPC RGB 7 Color USB Outlet Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
77
All Time:
1,542
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The port of the USB outlet on the keyboard can accumulate dust and dirt which can cause the connection between the keyboard and computer to fail. This guide will show how to replace the USB jack on the keyboard’s cord.
    1. CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: step 1, image 1 of 2 CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: step 1, image 2 of 2
      • Be sure to unplug the keyboard before starting the disassembly.
      • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
      Ask FixBot
    2. CyberPowerPC RGB 7 Color USB Outlet Replacement: step 2, image 1 of 2 CyberPowerPC RGB 7 Color USB Outlet Replacement: step 2, image 2 of 2
      • Remove the sixteen 5 mm length screws using the Phillips head #2.
      • One of the screws may be located underneath a manufacturer's sticker.
      Ask FixBot
    3. CyberPowerPC RGB 7 Color USB Outlet Replacement: step 3, image 1 of 1
      • Lift up and remove the plastic casing.
      Ask FixBot
    1. CyberPowerPC RGB 7 Color USB Outlet Replacement, LED Backlight: step 4, image 1 of 1
      • Remove the metal backing located directly underneath the white plastic casing.
      Ask FixBot
    2. CyberPowerPC RGB 7 Color USB Outlet Replacement: step 5, image 1 of 1
      • Be careful not to pull too hard on the ribbon cable, as it may break.
      • Disconnect the ribbon cable that connects the LED board to the motherboard.
      Ask FixBot
    3. CyberPowerPC RGB 7 Color USB Outlet Replacement: step 6, image 1 of 1
      • Carefully remove the LED board, which should now come free from the casing.
      Ask FixBot
    1. CyberPowerPC RGB 7 Color USB Outlet Replacement, USB Outlet: step 7, image 1 of 1
      • Remove the motherboard and its attached cable from the plastic casing. The cord should now be free and can be replaced.
      Ask FixBot
Author
with
Katherine Von Braunsberg
377 Reputation
3 Guides authored
USF Tampa, Team S15-G2, Boczar Spring 2018 Member of USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 77
All Time: 1,542
