Up to 20% off select tools
CyberPowerPC RGB 7 Color Motherboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
69
All Time:
1,110
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Over time the cable on the Motherboard may become loose or even break due to wear and tear. This guide will demonstrate how to replace the motherboard of the keyboard.
    1. CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: step 1, image 1 of 2 CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: step 1, image 2 of 2
      • Be sure to unplug the keyboard before starting the disassembly.
      • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
      Ask FixBot
    2. CyberPowerPC RGB 7 Color Motherboard Replacement: step 2, image 1 of 2 CyberPowerPC RGB 7 Color Motherboard Replacement: step 2, image 2 of 2
      • Remove the sixteen 5 mm length screws using the Phillips head #2.
      • One of the screws may be located underneath a manufacturer's sticker.
      Ask FixBot
    3. CyberPowerPC RGB 7 Color Motherboard Replacement: step 3, image 1 of 1
      • Lift up and remove the plastic casing.
      Ask FixBot
    1. CyberPowerPC RGB 7 Color Motherboard Replacement, LED Backlight: step 4, image 1 of 1
      • Remove the metal backing located directly underneath the white plastic casing.
      Ask FixBot
    2. CyberPowerPC RGB 7 Color Motherboard Replacement: step 5, image 1 of 1
      • Be careful not to pull too hard on the ribbon cable, as it may break.
      • Disconnect the ribbon cable that connects the LED board to the motherboard.
      Ask FixBot
    3. CyberPowerPC RGB 7 Color Motherboard Replacement: step 6, image 1 of 1
      • Carefully remove the LED board, which should now come free from the casing.
      Ask FixBot
    1. CyberPowerPC RGB 7 Color Motherboard Replacement, Motherboard: step 7, image 1 of 1
      • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
      Ask FixBot
    2. CyberPowerPC RGB 7 Color Motherboard Replacement: step 8, image 1 of 1
      • Remove the motherboard and its attached cable from the plastic casing. The cord should now come free to replace.
      Ask FixBot
Author
with
Katherine Von Braunsberg
377 Reputation
3 Guides authored
USF Tampa, Team S15-G2, Boczar Spring 2018 Member of USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 69
All Time: 1,110
