Up to 20% off select tools
CyberPowerPC RGB 7 Color LED Backlight Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
77
All Time:
1,806
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The LED backlight may burn out, causing the backlight to cease working properly. This guide will demonstrate how to replace the LED backlight.
    1. CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: step 1, image 1 of 2 CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: step 1, image 2 of 2
      • Be sure to unplug the keyboard before starting the disassembly.
      • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
      Ask FixBot
    2. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 2, image 1 of 2 CyberPowerPC RGB 7 Color LED Backlight Replacement: step 2, image 2 of 2
      • Remove the sixteen 5 mm length screws using the Phillips head #2.
      • One of the screws may be located underneath a manufacturer's sticker.
      Ask FixBot
    3. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 3, image 1 of 1
      • Lift up and remove the plastic casing.
      Ask FixBot
    1. CyberPowerPC RGB 7 Color LED Backlight Replacement, LED Backlight: step 4, image 1 of 1
      • Remove the metal backing located directly underneath the white plastic casing.
      Ask FixBot
    2. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 5, image 1 of 1
      • Be careful not to pull too hard on the ribbon cable, as it may break.
      • Disconnect the ribbon cable that connects the LED board to the motherboard.
      Ask FixBot
    3. CyberPowerPC RGB 7 Color LED Backlight Replacement: step 6, image 1 of 1
      • Carefully remove the LED board, which should now come free from the casing.
      Ask FixBot
2 other people completed this guide.
Author
with
Braydon Lantz
229 Reputation
2 Guides authored
USF Tampa, Team S15-G2, Boczar Spring 2018 Member of USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 77
All Time: 1,806
