CyberHome CH-DVD 300 Disc Tray Bracket Replacement
  1. CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Top Panel: step 1, image 1 of 2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Top Panel: step 1, image 2 of 2
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
    Ask FixBot
  2. CyberHome CH-DVD 300 Disc Tray Bracket Replacement: step 2, image 1 of 2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement: step 2, image 2 of 2
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
    Ask FixBot
  3. CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Disc Tray Bracket: step 3, image 1 of 2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement, Disc Tray Bracket: step 3, image 2 of 2
    • Remove the 6.3mm screws keeping the disc tray bracket connected to the disc tray.
    Ask FixBot
  4. CyberHome CH-DVD 300 Disc Tray Bracket Replacement: step 4, image 1 of 2 CyberHome CH-DVD 300 Disc Tray Bracket Replacement: step 4, image 2 of 2
    • Lift up on the bracket by:
    • Sliding the disc tray bracket forward.
    • Lifting the back edge up.
    Ask FixBot
4 other people completed this guide.
Chris Menezes
699 Reputation
5 Guides authored
Cal Poly, Team 6-5, Forte Spring 2014 Member of Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 41
All Time: 4,693
