Up to 20% off select tools
CyberHome CH-DVD 300 Back Panel Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
84
All Time:
1,279
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing the back panel requires taking of the top panel first. Then, you must remove four more screws on the back.
    1. CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: step 1, image 1 of 2 CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: step 1, image 2 of 2
      • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
      • Unplug the DVD player from the wall socket.
      • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
      Ask FixBot
    2. CyberHome CH-DVD 300 Back Panel Replacement: step 2, image 1 of 2 CyberHome CH-DVD 300 Back Panel Replacement: step 2, image 2 of 2
      • Remove the top panel of the DVD Player by:
      • Sliding the top panel backwards.
      • Gently lifting the back of the top panel up.
      Ask FixBot
    1. CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: step 3, image 1 of 2 CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: step 3, image 2 of 2
      • Remove the remaining screws on the back of the DVD player:
      • There will be four 15 mm screws and two 6.3 mm screws.
      Ask FixBot
    2. CyberHome CH-DVD 300 Back Panel Replacement: step 4, image 1 of 1
      • Remove the back panel by:
      • Lifting up on the back panel.
      • Pulling the back panel backwards from the DVD player.
      Ask FixBot
Author
with
Chris Menezes
699 Reputation
5 Guides authored
Cal Poly, Team 6-5, Forte Spring 2014 Member of Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 84
All Time: 1,279
