Cyber-shot DSC-H55 Lens Replacement
  1. Cyber-shot DSC-H55 Lens Replacement, Removing Screws: step 1, image 1 of 2 Cyber-shot DSC-H55 Lens Replacement, Removing Screws: step 1, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the two screws located on the right side of the camera.
    Ask FixBot
  2. Cyber-shot DSC-H55 Lens Replacement, Removing Bottom Piece: step 2, image 1 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Bottom Piece: step 2, image 2 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Bottom Piece: step 2, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the three screws on the bottom of the camera.
    • Use the plastic opening tool to lift the cover containing the patent information off.
    Ask FixBot
  3. Cyber-shot DSC-H55 Lens Replacement, Removing Left Side Piece: step 3, image 1 of 2 Cyber-shot DSC-H55 Lens Replacement, Removing Left Side Piece: step 3, image 2 of 2
    • Place the plastic opening tool in the crack between the metal circle and the black piece on the left.
    • Slide the black cover and lift to remove.
    Ask FixBot
  4. Cyber-shot DSC-H55 Lens Replacement, Removing Newly Exposed Screws: step 4, image 1 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Newly Exposed Screws: step 4, image 2 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Newly Exposed Screws: step 4, image 3 of 3
    • The first picture shows how the left side of the camera looks once we remove the side piece.
    • Use the Phillips #00 screwdriver to remove the two screws on this left side.
    • Flip your camera to the right side where we removed the first two screws.
    • Use the plastic opening tool into the crack and lift in order to loosen that side of the shell. Loosening one side makes removing the entire shell easier.
    Ask FixBot
  5. Cyber-shot DSC-H55 Lens Replacement, Removing Back Shell: step 5, image 1 of 2 Cyber-shot DSC-H55 Lens Replacement, Removing Back Shell: step 5, image 2 of 2
    • Once the side is loose, apply a small amount of force to remove the shell.
    • Remove one side and then the other to avoid breaking any piece of the camera.
    • Keep the battery compartment open to make this step easier.
    Ask FixBot
  6. Cyber-shot DSC-H55 Lens Replacement, Removing the Motherboard: step 6, image 1 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing the Motherboard: step 6, image 2 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing the Motherboard: step 6, image 3 of 3
    • Removing the outer shell will expose the motherboard (the green chip).
    • Carefully grab the motherboard and flip it over.
    • Locate the ribbon wire protruding from the motherboard. Grip the wire as close to the white square as possible and slightly pull it to disconnect it from the wire.
    Ask FixBot
  7. Cyber-shot DSC-H55 Lens Replacement, Detaching Metal around LCD Screen: step 7, image 1 of 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Metal around LCD Screen: step 7, image 2 of 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Metal around LCD Screen: step 7, image 3 of 3
    • Remove the LCD Screen to separate the metal frame connecting the screen to the camera.
    • Gently pull the metal frame away, keeping in mind that the right end of the screen is attached by a ribbon wire.
    • Slowly remove the metal frame until it fully pops off.
    Ask FixBot
  8. Cyber-shot DSC-H55 Lens Replacement, Detaching Ribbon Wires: step 8, image 1 of 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Ribbon Wires: step 8, image 2 of 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Ribbon Wires: step 8, image 3 of 3
    • Flip the metal screen to be facing down. There will be a small black clip on the white connector that will allows the ribbon wire to be removed.
    • Carefully lift the black clip and slide the ribbon out in order to remove the LCD screen.
    Ask FixBot
  9. Cyber-shot DSC-H55 Lens Replacement, Removing Top Shell: step 9, image 1 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Top Shell: step 9, image 2 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Top Shell: step 9, image 3 of 3
    • Remove the Phillips #00 screw located at the top middle of the camera.
    • There is a ribbon wire on the top right. Make sure to disconnect the ribbon wire as you did in the previous step.
    • Slowly and carefully pull up.
    Ask FixBot
  10. Cyber-shot DSC-H55 Lens Replacement, Removing Front Outer Shell: step 10, image 1 of 1
    • Pull off front outer shell by pushing off from left side.
    Ask FixBot
  11. Cyber-shot DSC-H55 Lens Replacement, Removing Ribbon Wires around Lens: step 11, image 1 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Ribbon Wires around Lens: step 11, image 2 of 3 Cyber-shot DSC-H55 Lens Replacement, Removing Ribbon Wires around Lens: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two orange screws located under the lens.
    • Remove the plastic by grabbing the right side of the camera and pushing it away in order for the plastic to come out.
    • By removing the plastic, we can now easily remove the ribbon wires by lifting the black clip and sliding ribbon wire out. Use tweezers if necessary.
    Ask FixBot
  12. Cyber-shot DSC-H55 Lens Replacement, Remove Lens: step 12, image 1 of 2 Cyber-shot DSC-H55 Lens Replacement, Remove Lens: step 12, image 2 of 2
    • Once the ribbons are detached, the lens is now completely detached from camera and can be replaced.
    Ask FixBot
Jazmin Young
608 Reputation
5 Guides authored
USF Tampa, Team 6-2, Brown Winter 2015 Member of USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 29
All Time: 2,533
