Cuisinart TOA-60FR Lightbulb Replacement
  1. Cuisinart TOA-60FR Lightbulb Replacement, Outside removal: step 1, image 1 of 1
    • Using a 25-hexagon head screwdriver, unscrew these three 7.31 mm screws.
    Ask FixBot
  2. Cuisinart TOA-60FR Lightbulb Replacement: step 2, image 1 of 2 Cuisinart TOA-60FR Lightbulb Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove all of these 7.31 mm screws.
    • Pull off the back panel.
    Ask FixBot
  3. Cuisinart TOA-60FR Lightbulb Replacement: step 3, image 1 of 3 Cuisinart TOA-60FR Lightbulb Replacement: step 3, image 2 of 3 Cuisinart TOA-60FR Lightbulb Replacement: step 3, image 3 of 3
    • Flip the oven upside down.
    • Use a spudger to pull out the grey stoppers.
    • Use a Phillips #1 screwdriver to remove all three 11 mm screws.
    Ask FixBot
  4. Cuisinart TOA-60FR Lightbulb Replacement: step 4, image 1 of 2 Cuisinart TOA-60FR Lightbulb Replacement: step 4, image 2 of 2
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the interior device.
    Ask FixBot
  5. Cuisinart TOA-60FR Lightbulb Replacement: step 5, image 1 of 3 Cuisinart TOA-60FR Lightbulb Replacement: step 5, image 2 of 3 Cuisinart TOA-60FR Lightbulb Replacement: step 5, image 3 of 3
    • Push down with a screw driver between the tabs, then pull up to release the tabs. Pull the top piece off.
    Ask FixBot
  6. Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: step 6, image 1 of 2 Cuisinart TOA-60FR Lightbulb Replacement, Lightbulb: step 6, image 2 of 2
    • Remove these two 12.8 mm screws at the top on each side.
    • Remove two 12.8 mm screws at the bottom, as demonstrated in the first picture.
    • You should now be able to push the back out with the four screws removed to see the light bulb.
    Ask FixBot
  7. Cuisinart TOA-60FR Lightbulb Replacement: step 7, image 1 of 1
    • Remove these four screws.
    • Pull the light away from it's window.
    Ask FixBot
  8. Cuisinart TOA-60FR Lightbulb Replacement: step 8, image 1 of 2 Cuisinart TOA-60FR Lightbulb Replacement: step 8, image 2 of 2
    • Using a wrench, remove the washer.
    • Pull the silver casing off the lightbulb.
    Ask FixBot
  9. Cuisinart TOA-60FR Lightbulb Replacement: step 9, image 1 of 2 Cuisinart TOA-60FR Lightbulb Replacement: step 9, image 2 of 2
    • Now unscrew the lightbulb to replace it with a new one.
    Ask FixBot
1 Guide Comment
You don't tell the information about the bulb! I'd like to buy one before I tear this oven apart.
Gary Richard Coulter - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 99
All Time: 1,410
