Cuisinart Mini-Prep DLC-2A Motor Replacement
  1. Cuisinart Mini-Prep DLC-2A Motor Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: step 1, image 1 of 2 Cuisinart Mini-Prep DLC-2A Motor Replacement, Cuisinart Mini-Prep DLC-2A Case Disassembly: step 1, image 2 of 2
    • Remove the back panel using a Phillips #1 Screwdriver on the four screws that hold it in place.
    Ask FixBot
  2. Cuisinart Mini-Prep DLC-2A Motor Replacement, Motor: step 2, image 1 of 3 Cuisinart Mini-Prep DLC-2A Motor Replacement, Motor: step 2, image 2 of 3 Cuisinart Mini-Prep DLC-2A Motor Replacement, Motor: step 2, image 3 of 3
    • Remove the three screws that hold the motor to the top case using a Phillips #1 screwdriver.
    Ask FixBot
  3. Cuisinart Mini-Prep DLC-2A Motor Replacement: step 3, image 1 of 3 Cuisinart Mini-Prep DLC-2A Motor Replacement: step 3, image 2 of 3 Cuisinart Mini-Prep DLC-2A Motor Replacement: step 3, image 3 of 3
    • Pull out the metal piece from the casing.
    • Pull apart the plastic casing that contains the rod.
    • Take off the plastic gears.
    Ask FixBot
  4. Cuisinart Mini-Prep DLC-2A Motor Replacement: step 4, image 1 of 2 Cuisinart Mini-Prep DLC-2A Motor Replacement: step 4, image 2 of 2
    • Use the Phillips #1 screwdriver to take off the screws that hold the white plastic to the metal piece.
    • Pull apart the white plastic from the metal piece.
    Ask FixBot
  5. Cuisinart Mini-Prep DLC-2A Motor Replacement: step 5, image 1 of 1
    • Use an electric screwdriver with a Phillips #1 head to take off the top metal piece.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 35
All Time: 1,066
