Cuisinart Griddler GR-4N Cooking Surfaces Replacement
  1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: step 1, image 1 of 2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: step 1, image 2 of 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
    Ask FixBot
  2. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: step 2, image 1 of 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
    Ask FixBot
  3. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: step 3, image 1 of 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
    Ask FixBot
  4. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: step 4, image 1 of 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
    Ask FixBot
  5. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: step 5, image 1 of 2 Cuisinart Griddler GR-4N Cooking Surfaces Replacement: step 5, image 2 of 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
    Ask FixBot
Kayla Londono
674 Reputation
4 Guides authored
Cal Poly, Team 1-12, Maness Spring 2016 Member of Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Members
6 Guides authored
1 Guide Comment
The 'cooking plates' on my unit always fall off. I tried bending the tabs to make it tighter - did not help. Any ideas?
M S - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 4,952
