Up to 20% off select tools
Cuisinart Griddler GR- 4N Button Spring Replacement
Views: 5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
116
All Time:
5,030
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your cooking surface isn't turning on or is being pushed up you may need to replace a spring, a process which will be explained in this guide.
    1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: step 1, image 1 of 2 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: step 1, image 2 of 2
      • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
      • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
      Ask FixBot
    2. Cuisinart Griddler GR- 4N Button Spring Replacement: step 2, image 1 of 1
      • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
      Ask FixBot
    3. Cuisinart Griddler GR- 4N Button Spring Replacement: step 3, image 1 of 1
      • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
      Ask FixBot
    4. Cuisinart Griddler GR- 4N Button Spring Replacement: step 4, image 1 of 1
      • Remove the single 5.5 mm Phillips #2 screw next to center black button.
      • After removing the center screw the metal plate should be free to remove.
      Ask FixBot
    5. Cuisinart Griddler GR- 4N Button Spring Replacement: step 5, image 1 of 2 Cuisinart Griddler GR- 4N Button Spring Replacement: step 5, image 2 of 2
      • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
      • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
      • The aligned parts will allow the cooking surfaces to work properly.
      Ask FixBot
    1. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: step 6, image 1 of 1
      • Depress one of the gray tabs on the side of the housing.
      Ask FixBot
    2. Cuisinart Griddler GR- 4N Button Spring Replacement: step 7, image 1 of 1
      • Pull out the black button and the spring will also come out within it.
      Ask FixBot
    3. Cuisinart Griddler GR- 4N Button Spring Replacement: step 8, image 1 of 1
      • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
      Ask FixBot
3 other people completed this guide.
Author
with
Laine Aro
173 Reputation
1 Guide authored
Cal Poly, Team 1-12, Maness Spring 2016 Member of Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 116
All Time: 5,030
