Cuisinart DLC-8F Power Cable Replacement
    1. Cuisinart DLC-8F Power Cable Replacement, Power Cable: step 1, image 1 of 2 Cuisinart DLC-8F Power Cable Replacement, Power Cable: step 1, image 2 of 2
      • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
      Ask FixBot
    2. Cuisinart DLC-8F Power Cable Replacement: step 2, image 1 of 2 Cuisinart DLC-8F Power Cable Replacement: step 2, image 2 of 2
      • Gently lift the bottom cover from the main body.
      Ask FixBot
    3. Cuisinart DLC-8F Power Cable Replacement: step 3, image 1 of 1
      • Remove the two 62 mm Phillips #2 screws from the cable retaining clip.
      Ask FixBot
    4. Cuisinart DLC-8F Power Cable Replacement: step 4, image 1 of 2 Cuisinart DLC-8F Power Cable Replacement: step 4, image 2 of 2
      • Lift off the cable retaining
      Ask FixBot
    5. Cuisinart DLC-8F Power Cable Replacement: step 5, image 1 of 2 Cuisinart DLC-8F Power Cable Replacement: step 5, image 2 of 2
      • Pull apart the two wires of the power cable at their connections as shown.
      Ask FixBot
    6. Cuisinart DLC-8F Power Cable Replacement: step 6, image 1 of 2 Cuisinart DLC-8F Power Cable Replacement: step 6, image 2 of 2
      • Lift out the cable.
      Ask FixBot
2 other people completed this guide.
David Colman
573 Reputation
4 Guides authored
Cal Poly, Team 8-6, Banghart Winter 2017 Member of Cal Poly, Team 8-6, Banghart Winter 2017
CPSU-BANGHART-W17S8G6
4 Members
48 Guides authored
1 Guide Comment
So you pull apart the wires of the power cable and then what? Instructions seem incomplete.
nancimoll1 - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 704
