Cuisinart DGB-650 Heating Element Replacement
  1. Cuisinart DGB-650 Heating Element Replacement, Heating Element: step 1, image 1 of 3 Cuisinart DGB-650 Heating Element Replacement, Heating Element: step 1, image 2 of 3 Cuisinart DGB-650 Heating Element Replacement, Heating Element: step 1, image 3 of 3
    • Turn the coffee maker upside down.
    • Remove the four 1.2 mm screws using a Phillips #0 screwdriver.
    • Remove the bottom cover to expose the heating element and pipes.
    Ask FixBot
  2. Cuisinart DGB-650 Heating Element Replacement: step 2, image 1 of 3 Cuisinart DGB-650 Heating Element Replacement: step 2, image 2 of 3 Cuisinart DGB-650 Heating Element Replacement: step 2, image 3 of 3
    • Firmly grasp both pipe endings next to the motherboard and gently pull both ends out.
    Ask FixBot
  3. Cuisinart DGB-650 Heating Element Replacement: step 3, image 1 of 2 Cuisinart DGB-650 Heating Element Replacement: step 3, image 2 of 2
    • Remove the two 1.2 mm screws keeping the pipe clamp attached using a Phillips #0 screwdriver.
    • Lift the pipe clamp up and set it aside.
    Ask FixBot
  4. Cuisinart DGB-650 Heating Element Replacement: step 4, image 1 of 2 Cuisinart DGB-650 Heating Element Replacement: step 4, image 2 of 2
    • Wedge the metal spudger between the heating element and the plastic.
    • Remove the heating element.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 289
