Cuisinart DFP-14BCN Switch Replacement
    1. Cuisinart DFP-14BCN Switch Replacement, Bowl: step 1, image 1 of 3 Cuisinart DFP-14BCN Switch Replacement, Bowl: step 1, image 2 of 3 Cuisinart DFP-14BCN Switch Replacement, Bowl: step 1, image 3 of 3
      • Unplug your food processor before starting any disassembly.
      • Remove the small pusher by rotating it clockwise and lifting up.
      Ask FixBot
    2. Cuisinart DFP-14BCN Switch Replacement: step 2, image 1 of 1
      • Remove the large pusher by grabbing its sides and pulling up.
      • There may be a clicking sound from the safety feature being disengaged in this step.
      Ask FixBot
    3. Cuisinart DFP-14BCN Switch Replacement: step 3, image 1 of 3 Cuisinart DFP-14BCN Switch Replacement: step 3, image 2 of 3 Cuisinart DFP-14BCN Switch Replacement: step 3, image 3 of 3
      • Remove the lid from the bowl by turning it clockwise and lifting.
      Ask FixBot
    4. Cuisinart DFP-14BCN Switch Replacement: step 4, image 1 of 1
      • Take out the blades by grabbing the plastic center piece and lifting up.
      • Avoid contact with blades as they are extremely sharp.
      Ask FixBot
    5. Cuisinart DFP-14BCN Switch Replacement: step 5, image 1 of 3 Cuisinart DFP-14BCN Switch Replacement: step 5, image 2 of 3 Cuisinart DFP-14BCN Switch Replacement: step 5, image 3 of 3
      • Position the handle of the bowl so that it is on your left.
      • Grab the handle and push clockwise. Lift up the bowl to remove it.
      Ask FixBot
    1. Cuisinart DFP-14BCN Switch Replacement, Back Casing: step 6, image 1 of 2 Cuisinart DFP-14BCN Switch Replacement, Back Casing: step 6, image 2 of 2
      • Turn the food processor's base upside down by lifting it up and turning it over.
      • Position the base so that the on and pulse buttons are facing you.
      • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
      Ask FixBot
    2. Cuisinart DFP-14BCN Switch Replacement: step 7, image 1 of 2 Cuisinart DFP-14BCN Switch Replacement: step 7, image 2 of 2
      • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
      Ask FixBot
    3. Cuisinart DFP-14BCN Switch Replacement: step 8, image 1 of 3 Cuisinart DFP-14BCN Switch Replacement: step 8, image 2 of 3 Cuisinart DFP-14BCN Switch Replacement: step 8, image 3 of 3
      • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
      • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
      Ask FixBot
    4. Cuisinart DFP-14BCN Switch Replacement: step 9, image 1 of 2 Cuisinart DFP-14BCN Switch Replacement: step 9, image 2 of 2
      • Lift off the back casing by raising it upward.
      Ask FixBot
    1. Cuisinart DFP-14BCN Switch Replacement, Buttons: step 10, image 1 of 3 Cuisinart DFP-14BCN Switch Replacement, Buttons: step 10, image 2 of 3 Cuisinart DFP-14BCN Switch Replacement, Buttons: step 10, image 3 of 3
      • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
      Ask FixBot
    2. Cuisinart DFP-14BCN Switch Replacement: step 11, image 1 of 2 Cuisinart DFP-14BCN Switch Replacement: step 11, image 2 of 2
      • Lift out the button assembly by pulling up.
      Ask FixBot
    3. Cuisinart DFP-14BCN Switch Replacement: step 12, image 1 of 1
      • Remove the two 5.5mm nuts with a 5.5mm nut driver.
      Ask FixBot
    4. Cuisinart DFP-14BCN Switch Replacement: step 13, image 1 of 3 Cuisinart DFP-14BCN Switch Replacement: step 13, image 2 of 3 Cuisinart DFP-14BCN Switch Replacement: step 13, image 3 of 3
      • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
      • The screws have glue in their threads, so this step might require a little extra force.
      • Slide off the switch and yellow plastic to remove the button assembly.
      Ask FixBot
    1. Cuisinart DFP-14BCN Switch Replacement, Switch: step 14, image 1 of 2 Cuisinart DFP-14BCN Switch Replacement, Switch: step 14, image 2 of 2
      • Desolder the white, black and red connections from the switch by using a soldering iron.
      • Refer to the soldering guide for extra help.
      • For reassembly, the new switch's connections will have to be soldered on.
      Ask FixBot
Sonya Dick
367 Reputation
3 Guides authored
Cal Poly, Team 10-3, Livingston Fall 2016 Member of Cal Poly, Team 10-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G3
3 Members
84 Guides authored
1 Guide Comment
You had me until the desoldering, maybe I’m just a wimp! Thanks anyway … good description!
dmdudek - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 32
All Time: 2,145
