Cuisinart DCC-1200 Hose Replacement
Views: 20K
View statistics:
Past 24 Hours:
4
Past 7 Days:
48
Past 30 Days:
157
All Time:
19,707
Comments: 25
13 comments on steps, 12 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Does your Cuisinart coffee maker leak water from the bottom of the machine? This guide will show how to fix the problem by checking and replacing the internal hoses. You will need a tweezers and the bit driver with the T10 driver bit.
Tools
    1. Cuisinart DCC-1200  Hose Replacement, Water Hoses: step 1, image 1 of 3 Cuisinart DCC-1200  Hose Replacement, Water Hoses: step 1, image 2 of 3 Cuisinart DCC-1200  Hose Replacement, Water Hoses: step 1, image 3 of 3
      • Flip the coffee maker over so the bottom is facing upwards.
      • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
      • Lift the bottom cover off the bottom of the coffee maker.
      Ask FixBot
    2. Cuisinart DCC-1200  Hose Replacement: step 2, image 1 of 2 Cuisinart DCC-1200  Hose Replacement: step 2, image 2 of 2
      • Gently squeeze the hose clamps together and begin moving the metal clamp away from the heating element.
      Ask FixBot
    3. Cuisinart DCC-1200  Hose Replacement: step 3, image 1 of 3 Cuisinart DCC-1200  Hose Replacement: step 3, image 2 of 3 Cuisinart DCC-1200  Hose Replacement: step 3, image 3 of 3
      • Gently pull on the loose hose to remove it from the heating element.
      Ask FixBot
    4. Cuisinart DCC-1200  Hose Replacement: step 4, image 1 of 3 Cuisinart DCC-1200  Hose Replacement: step 4, image 2 of 3 Cuisinart DCC-1200  Hose Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Squeeze the clamp with tweezers on the opposite end of the hose from the one you already removed.
      • Once the clamp is free, gently pull upwards on the hose to remove it.
      • Replace the disconnected hose with a new functioning hose.
      Ask FixBot
4 other people completed this guide.
Austin Wheaton
903 Reputation
4 Guides authored
UW Stout, Team S8-G1, Ogden Spring 2018 Member of UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Members
60 Guides authored
12 Guide Comments
I think this was a brand new coffee maker used for this demo. My hoses will not budge. I would guess they soften up and permanently adhere to heating element over time. Also, from other videos, there is a ball in the hose (to control direction of water.) Not sure if you can replace with any old hose.
George Heynen - Reply Share
Oh yeah that really helped, why not tell us where you got the hose or what type it is?
Silicon Durometer 50 or 70 or is it something else, totally useless site, waste of time.
Ronald Swapp - Reply Share
Wish someone would answer this good question…
kenzenmaster - Reply Share
Where to get, and what kind of replacement hoses ??? Do you need a new ball in little filter , or do you need the filter at all ???
https://www.amazon.com/gp/product/B003SY... this is where I ordered red hose from. $5.69 for a foot.
Mike carey - Reply Share
Past 24 Hours: 4
Past 7 Days: 48
Past 30 Days: 157
All Time: 19,707
