Cuisinart DCC-1100 Heating Element Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
74
All Time:
4,256
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
In this guide you will learn how to replace the Cuisinart DCC-1100 Heating Element if you are having issues with the device heating up. Please have a replacement heating element ready and potentially extra thermal paste. Also unplug the machine before beginning work.
Tools
    1. Cuisinart DCC-1100 Heating Element Replacement, Heating Element: step 1, image 1 of 3 Cuisinart DCC-1100 Heating Element Replacement, Heating Element: step 1, image 2 of 3 Cuisinart DCC-1100 Heating Element Replacement, Heating Element: step 1, image 3 of 3
      • Remove the coffee pot and unplug the maker.
      • Flip the coffee maker over so that way the bottom is facing you.
      Ask FixBot
    2. Cuisinart DCC-1100 Heating Element Replacement: step 2, image 1 of 3 Cuisinart DCC-1100 Heating Element Replacement: step 2, image 2 of 3 Cuisinart DCC-1100 Heating Element Replacement: step 2, image 3 of 3
      • Remove the five 1.6mm Phillips #1 screws from the bottom.
      • Remove the bottom cover.
      Ask FixBot
    3. Cuisinart DCC-1100 Heating Element Replacement: step 3, image 1 of 2 Cuisinart DCC-1100 Heating Element Replacement: step 3, image 2 of 2
      • Remove the two 1.6mm Phillips #0 screws from the heating element.
      • Lift up the heating element and remove the hot plate.
      Ask FixBot
    4. Cuisinart DCC-1100 Heating Element Replacement: step 4, image 1 of 2 Cuisinart DCC-1100 Heating Element Replacement: step 4, image 2 of 2
      • Disconnect the heating element.
      • Pinch the tube clips and remove from tubes from the heating element.
      Ask FixBot
3 other people completed this guide.
Tanvirul Arafin
155 Reputation
1 Guide authored
USF Tampa, Team S20-G4, Passmore Spring 2018 Member of USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 74
All Time: 4,256
