Cuisinart DCC-1100 Drip Spring Replacement
Views: 14K
View statistics:
Past 24 Hours:
5
Past 7 Days:
37
Past 30 Days:
156
All Time:
14,321
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This replacement guide will help you get through all of the top pieces such as the filter element to get to the drip spring. It is possible for this spring to break causing issues with the drip function or rust possibly causing a strange taste.
    1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: step 1, image 1 of 1
      • Unplug the coffee maker.
      Ask FixBot
    2. Cuisinart DCC-1100 Drip Spring Replacement: step 2, image 1 of 1
      • Remove the coffee pot and open the top lid.
      Ask FixBot
    3. Cuisinart DCC-1100 Drip Spring Replacement: step 3, image 1 of 2 Cuisinart DCC-1100 Drip Spring Replacement: step 3, image 2 of 2
      • Remove the basket filter holder.
      Ask FixBot
    4. Cuisinart DCC-1100 Drip Spring Replacement: step 4, image 1 of 1
      • Remove the basket filter from the holder.
      Ask FixBot
    5. Cuisinart DCC-1100 Drip Spring Replacement: step 5, image 1 of 1
      • Press up on the drip spring mechanism.
      Ask FixBot
    6. Cuisinart DCC-1100 Drip Spring Replacement: step 6, image 1 of 2 Cuisinart DCC-1100 Drip Spring Replacement: step 6, image 2 of 2
      • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
      Ask FixBot
    7. Cuisinart DCC-1100 Drip Spring Replacement: step 7, image 1 of 1
      • Remove the spring from the dripper.
      Ask FixBot
8 other people completed this guide.
Josh Harvey
910 Reputation
4 Guides authored
USF Tampa, Team S20-G4, Passmore Spring 2018 Member of USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Members
84 Guides authored
4 Guide Comments
Where do you find replacement springs?
Mrich - Reply Share
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett - Reply Share
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - Reply Share
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - Reply Share
Past 24 Hours: 5
Past 7 Days: 37
Past 30 Days: 156
All Time: 14,321
