Cuisinart DCC-1100 Display Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
10
Past 30 Days:
59
All Time:
1,554
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 50 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show you how to replace the display and will require soldering.
Tools
    1. Cuisinart DCC-1100 Display Replacement, Display: step 1, image 1 of 2 Cuisinart DCC-1100 Display Replacement, Display: step 1, image 2 of 2
      • Unplug the coffee maker and remove the pot.
      Ask FixBot
    2. Cuisinart DCC-1100 Display Replacement: step 2, image 1 of 2 Cuisinart DCC-1100 Display Replacement: step 2, image 2 of 2
      • Open the lid of the coffee pot.
      • Remove the two 1.6mm Phillips #1 screws from inside of the lid.
      Ask FixBot
    3. Cuisinart DCC-1100 Display Replacement: step 3, image 1 of 1
      • Remove the lid.
      Ask FixBot
    4. Cuisinart DCC-1100 Display Replacement: step 4, image 1 of 1
      • Remove the two 1.3mm Phillips #0 screws from the display.
      Ask FixBot
    5. Cuisinart DCC-1100 Display Replacement: step 5, image 1 of 2 Cuisinart DCC-1100 Display Replacement: step 5, image 2 of 2
      • Slide the display into the coffee maker so that way you can access the screws in the back.
      • Remove the four 1mm Phillips #0 screws from the back of the display.
      Ask FixBot
    6. Cuisinart DCC-1100 Display Replacement: step 6, image 1 of 2 Cuisinart DCC-1100 Display Replacement: step 6, image 2 of 2
      • Remove the back panel from the display.
      • Remove the 1mm Phillips #0 screw from the motherboard.
      Ask FixBot
    7. Cuisinart DCC-1100 Display Replacement: step 7, image 1 of 1
      • Desolder the display from the motherboard.
      Ask FixBot
2 other people completed this guide.
Josh Harvey
910 Reputation
4 Guides authored
USF Tampa, Team S20-G4, Passmore Spring 2018 Member of USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 59
All Time: 1,554
