Cuisinart CPT-140BK Circuit Board Replacement
  1. Cuisinart CPT-140BK  Circuit Board Replacement, Circuit Board: step 1, image 1 of 1
    • Unplug the toaster before disassembly.
    Ask FixBot
  2. Cuisinart CPT-140BK  Circuit Board Replacement: step 2, image 1 of 2 Cuisinart CPT-140BK  Circuit Board Replacement: step 2, image 2 of 2
    • Turn the toaster upside down.
    • Unscrew all 4mm screws using Phillips #2 screwdriver.
    Ask FixBot
  3. Cuisinart CPT-140BK  Circuit Board Replacement: step 3, image 1 of 1
    • Turn the toaster right side up.
    • Lift up the front cover carefully because the cables can be damaged.
    • Pull out the toaster lever knobs by pulling it away from the toaster before removing the top cover.
    Ask FixBot
  4. Cuisinart CPT-140BK  Circuit Board Replacement: step 4, image 1 of 3 Cuisinart CPT-140BK  Circuit Board Replacement: step 4, image 2 of 3 Cuisinart CPT-140BK  Circuit Board Replacement: step 4, image 3 of 3
    • Detach the cable that connects the toaster to the circuit board, in both control panels.
    Ask FixBot
  5. Cuisinart CPT-140BK  Circuit Board Replacement: step 5, image 1 of 1
    • Carefully lift up the top cover.
    Ask FixBot
  6. Cuisinart CPT-140BK  Circuit Board Replacement: step 6, image 1 of 3 Cuisinart CPT-140BK  Circuit Board Replacement: step 6, image 2 of 3 Cuisinart CPT-140BK  Circuit Board Replacement: step 6, image 3 of 3
    • The circuit board is located inside the front cover.
    • Unscrew total of six 4mm screws that attach each circuit board to the top cover, using Phillips #2 screwdriver.
    • Remove and replace the circuit board.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 796
