Cuisinart CPB-380 Motor Replacement
    1. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: step 1, image 1 of 3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: step 1, image 2 of 3 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: step 1, image 3 of 3
      • Turn the device upside down.
      • Remove all four rubber feet by prying them out using the metal spudger.
      • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
      Ask FixBot
    2. Cuisinart CPB-380 Motor Replacement: step 2, image 1 of 2 Cuisinart CPB-380 Motor Replacement: step 2, image 2 of 2
      • Remove the base from the body of the blender.
      Ask FixBot
    3. Cuisinart CPB-380 Motor Replacement: step 3, image 1 of 3 Cuisinart CPB-380 Motor Replacement: step 3, image 2 of 3 Cuisinart CPB-380 Motor Replacement: step 3, image 3 of 3
      • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
      • Gently move the wire aside so that it is not in the way.
      Ask FixBot
    4. Cuisinart CPB-380 Motor Replacement: step 4, image 1 of 3 Cuisinart CPB-380 Motor Replacement: step 4, image 2 of 3 Cuisinart CPB-380 Motor Replacement: step 4, image 3 of 3
      • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
      • Gently remove the black cover.
      • Underneath, you will see a clear plastic cover that should be removed as well.
      Ask FixBot
    5. Cuisinart CPB-380 Motor Replacement: step 5, image 1 of 2 Cuisinart CPB-380 Motor Replacement: step 5, image 2 of 2
      • Cut the zip tie that holds the black, blue, red, and yellow wires together.
      • Take care not to cut the wires.
      Ask FixBot
    1. Cuisinart CPB-380 Motor Replacement, Motor: step 6, image 1 of 2 Cuisinart CPB-380 Motor Replacement, Motor: step 6, image 2 of 2
      • Remove the four 13mm screws holding down the frame located at the bottom of the inverted blender using the Phillips #2 screwdriver.
      • Remove frame.
      Ask FixBot
    2. Cuisinart CPB-380 Motor Replacement: step 7, image 1 of 2 Cuisinart CPB-380 Motor Replacement: step 7, image 2 of 2
      • Grab the motor by the black gear and the white filter.
      • Unscrew the black gear.
      Ask FixBot
    3. Cuisinart CPB-380 Motor Replacement: step 8, image 1 of 3 Cuisinart CPB-380 Motor Replacement: step 8, image 2 of 3 Cuisinart CPB-380 Motor Replacement: step 8, image 3 of 3
      • With the metal spudger remove the four rubber stoppers.
      • Remove the four 13mm screws with the Phillips #2 screwdriver.
      Ask FixBot
    4. Cuisinart CPB-380 Motor Replacement: step 9, image 1 of 1
      • Separate the top from the motor.
      • Pinch perpendicular to the flat surface and pull out the blue wire.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
What is the part number and price for Cuisinart CPB-380 Motor?
Paul Hagen - Reply Share
What is the part number and price for Cuisinart CBD-380 motor and price....
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 53
All Time: 4,376
