Cub Cadet LT1042 Starter Replacement
    1. Cub Cadet LT1042 Starter Replacement, Starter: step 1, image 1 of 3 Cub Cadet LT1042 Starter Replacement, Starter: step 1, image 2 of 3 Cub Cadet LT1042 Starter Replacement, Starter: step 1, image 3 of 3
      • Remove the plastic covers from the battery terminals.
      • Use a wrench to disconnect the lawn mower battery terminals.
      • Disconnect the battery by removing the negative (black) terminal first, followed by the positive (red) terminal.
      • When reassembling, reconnect the battery in reverse order: positive terminal first, then negative.
      Ask FixBot
    2. Cub Cadet LT1042 Starter Replacement: step 2, image 1 of 3 Cub Cadet LT1042 Starter Replacement: step 2, image 2 of 3 Cub Cadet LT1042 Starter Replacement: step 2, image 3 of 3
      • Use a wrench to unfasten the cable that connects to the battery.
      Ask FixBot
    3. Cub Cadet LT1042 Starter Replacement: step 3, image 1 of 2 Cub Cadet LT1042 Starter Replacement: step 3, image 2 of 2
      • Use wrench and unfasten the two top bolts that hold the old starter in place.
      Ask FixBot
    4. Cub Cadet LT1042 Starter Replacement: step 4, image 1 of 2 Cub Cadet LT1042 Starter Replacement: step 4, image 2 of 2
      • Remove the old starter.
      • Replace it with the new starter.
      Ask FixBot
    5. Cub Cadet LT1042 Starter Replacement: step 5, image 1 of 2 Cub Cadet LT1042 Starter Replacement: step 5, image 2 of 2
      • Fasten the new starter in place by tightening the two bolts at the top with the wrench.
      Ask FixBot
    6. Cub Cadet LT1042 Starter Replacement: step 6, image 1 of 1
      • Refasten the cable that leads to the battery to the bottom bolt of the new starter.
      Ask FixBot
    7. Cub Cadet LT1042 Starter Replacement: step 7, image 1 of 3 Cub Cadet LT1042 Starter Replacement: step 7, image 2 of 3 Cub Cadet LT1042 Starter Replacement: step 7, image 3 of 3
      • Reconnect the battery by fastening the positive (red) terminal first, followed by the negative (black) terminal.
      Ask FixBot
Greilis Salazar
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 127
All Time: 1,577
