CrystalView NB4-35788 Battery Replacement
    1. CrystalView NB4-35788 Battery Replacement, Battery: step 1, image 1 of 1
      • Power off the device before beginning disassembly.
      • Using a Phillips #00 Screwdriver, take out the following screws:
      • Two 6 mm screws
      • Three 4 mm screws
      • Four 3 mm screws
      • These screws can be taken out in any order.
      Ask FixBot
    2. CrystalView NB4-35788 Battery Replacement: step 2, image 1 of 1
      • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
      Ask FixBot
    3. CrystalView NB4-35788 Battery Replacement: step 3, image 1 of 1
      • Remove the cover off the back of the device.
      Ask FixBot
    4. CrystalView NB4-35788 Battery Replacement: step 4, image 1 of 1
      • Remove the battery using a plastic spudger.
      • Do not use a metal spudger, as this can damage the device.
      Ask FixBot
    5. CrystalView NB4-35788 Battery Replacement: step 5, image 1 of 2 CrystalView NB4-35788 Battery Replacement: step 5, image 2 of 2
      • Peel back the yellow film on the old battery to expose the red and black wires
      • De-solder these wires to disconnect the old battery
      • Be careful while using a soldering iron as it is extremely hot.
      • Follow the How To Solder and Desolder Connections guide for help.
      Ask FixBot
Courtney Clark
218 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 24
All Time: 537
