Crosley 33301 Front Glass Replacement
    1. Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: step 1, image 1 of 3 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: step 1, image 2 of 3 Crosley 33301 Front Glass Replacement, Crosley 33301 Front Glass: step 1, image 3 of 3
      • Rotate Clock till the face/or front is pointing away from you.
      • Continue on by unscrewing the 5.5 millimeter screws with your hands.
      • Once all the screws are removed, take the circular back panel off and lay it down flat on a stable surface to put back on later.
      Ask FixBot
    2. Crosley 33301 Front Glass Replacement: step 2, image 1 of 2 Crosley 33301 Front Glass Replacement: step 2, image 2 of 2
      • Unscrew the two remaining screws with a PH2 bit.
      • Do not be afraid to use additional force to remove these screws. Just be careful not to break the clock!
      Ask FixBot
    3. Crosley 33301 Front Glass Replacement: step 3, image 1 of 2 Crosley 33301 Front Glass Replacement: step 3, image 2 of 2
      • Remove the front part of the clock from the back frame.
      • No major force is required. The back frame should slide right off.
      Ask FixBot
    4. Crosley 33301 Front Glass Replacement: step 4, image 1 of 2 Crosley 33301 Front Glass Replacement: step 4, image 2 of 2
      • You will notice that there are three small indents on alternate sides.
      • You will see small slits where the indents can slide through.
      • Twist the center counter clockwise so that the face and the back are no longer connected.
      Ask FixBot
    5. Crosley 33301 Front Glass Replacement: step 5, image 1 of 2 Crosley 33301 Front Glass Replacement: step 5, image 2 of 2
      • Replace the front of the clock with your new glass face protector and settle it on the frame.
      • The glass for this clock is 10cm in diameter. It would be best to use glass that fits this measurement!
      Ask FixBot
    6. Crosley 33301 Front Glass Replacement: step 6, image 1 of 3 Crosley 33301 Front Glass Replacement: step 6, image 2 of 3 Crosley 33301 Front Glass Replacement: step 6, image 3 of 3
      • Apply the clock face back on the frame, then reverse your steps. Take a step back and admire your handiwork!
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 2,890
