Crock-Pot Express Crock Multi-Cooker Heating Element Replacement
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Power Cord: step 1, image 1 of 1
      • Remove the power cord from the wall outlet first, disconnecting power from the device.
      Ask FixBot
    2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 2, image 1 of 1
      • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
      Ask FixBot
    3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 3, image 1 of 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 3, image 2 of 2
      • Grasp the power cord input connector firmly with forefinger and thumb.
      • Without tugging, apply pulling force until the connector is free from device
      Ask FixBot
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: step 4, image 1 of 3 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: step 4, image 2 of 3 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: step 4, image 3 of 3
      • Orient the crock pot where the lid locked and unlocked icons are visible.
      • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
      • Remove the lid.
      Ask FixBot
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Heating Element: step 5, image 1 of 1
      • Remove the inner pot and set it aside for reassembly.
      Ask FixBot
    2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 6, image 1 of 1
      • Carefully rotate the Crock-Pot so that the bottom is facing upward, allowing access to the electrical panel.
      • Remove the two 12.4 mm screws with a Phillips #2 screwdriver.
      Ask FixBot
    3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 7, image 1 of 1
      • Rotate the electrical panel cover counter clockwise and pull up until the panel comes free.
      Ask FixBot
    4. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 8, image 1 of 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 8, image 2 of 2
      • Remove 3 nuts, 3 washers, 3 spacers, and 3 lock washers using an adjustable wrench to free the heating element from the Crock-Pot housing.
      Ask FixBot
    5. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 9, image 1 of 1
      • Remove the 10mm screw and metal plate beneath the electrical nodes using a Phillips #2 screwdriver.
      Ask FixBot
    6. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 10, image 1 of 1
      • Remove the 2 red wires from the terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as red.
      • Remove 1 white wire from terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as white.
      Ask FixBot
    7. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 11, image 1 of 1
      • Reorient the crockpot on its side to prepare for the heating element removal.
      Ask FixBot
    8. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 12, image 1 of 1
      • Carefully pull the heating element out and rotate it until bottom side is facing up out of the pot.
      Ask FixBot
    9. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 13, image 1 of 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: step 13, image 2 of 2
      • Remove both 19mm screws from the cutout switch housing using a Phillips #2 screwdriver, freeing the heating element from the device.
      • Carefully remove the heating element from the device.
      Ask FixBot
3 other people completed this guide.
2 Guide Comments
where do you get a heating element?
Stephanie Brown - Reply Share
Ma machine j'ai acheté neuf et elle s'allume pas
MOHAMED DJA YAHIA - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 66
All Time: 6,166
