Cricut Personal Logic Board Replacement
  1. Cricut Personal Logic Board Replacement, Access through the bottom: step 1, image 1 of 2 Cricut Personal Logic Board Replacement, Access through the bottom: step 1, image 2 of 2
    • Remove the 7 screws on the bottom. Then, wiggle the bottom panel free.
    • The logic board will be immediately exposed-- Take care not to mangle any of the connectors, or bump any capacitors.
    • The cartridge slot also comes out attached to the bottom panel.
    Ask FixBot
  2. Cricut Personal Logic Board Replacement, Remove connectors: step 2, image 1 of 2 Cricut Personal Logic Board Replacement, Remove connectors: step 2, image 2 of 2
    • Remove all 8 connectors, plus the cartridge reader connector.
    • Refer to the images to remember where each connector plugs into.
    Ask FixBot
  3. Cricut Personal Logic Board Replacement, Remove the board: step 3, image 1 of 3 Cricut Personal Logic Board Replacement, Remove the board: step 3, image 2 of 3 Cricut Personal Logic Board Replacement, Remove the board: step 3, image 3 of 3
    • Remove the 4 screws holding in the logic board.
    • The power connector will be stuck. The power connector has a lip on it-- lift the back of the board up and out to free the lip.
    Ask FixBot
Windey777
124 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 276
