Cricut Maker Roller Bar Replacement
  1. Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: step 1, image 1 of 3 Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: step 1, image 2 of 3 Cricut Maker Roller Bar Replacement, Cricut Maker Lid Replacement: step 1, image 3 of 3
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
    Ask FixBot
  2. Cricut Maker Roller Bar Replacement: step 2, image 1 of 2 Cricut Maker Roller Bar Replacement: step 2, image 2 of 2
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
    Ask FixBot
  3. Cricut Maker Roller Bar Replacement: step 3, image 1 of 3 Cricut Maker Roller Bar Replacement: step 3, image 2 of 3 Cricut Maker Roller Bar Replacement: step 3, image 3 of 3
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
    Ask FixBot
  4. Cricut Maker Roller Bar Replacement: step 4, image 1 of 1
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
    Ask FixBot
  5. Cricut Maker Roller Bar Replacement, Front Door Replacement: step 5, image 1 of 2 Cricut Maker Roller Bar Replacement, Front Door Replacement: step 5, image 2 of 2
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
    Ask FixBot
  6. Cricut Maker Roller Bar Replacement: step 6, image 1 of 3 Cricut Maker Roller Bar Replacement: step 6, image 2 of 3 Cricut Maker Roller Bar Replacement: step 6, image 3 of 3
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
    Ask FixBot
  7. Cricut Maker Roller Bar Replacement: step 7, image 1 of 3 Cricut Maker Roller Bar Replacement: step 7, image 2 of 3 Cricut Maker Roller Bar Replacement: step 7, image 3 of 3
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
    Ask FixBot
  8. Cricut Maker Roller Bar Replacement: step 8, image 1 of 3 Cricut Maker Roller Bar Replacement: step 8, image 2 of 3 Cricut Maker Roller Bar Replacement: step 8, image 3 of 3
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
    Ask FixBot
  9. Cricut Maker Roller Bar Replacement: step 9, image 1 of 2 Cricut Maker Roller Bar Replacement: step 9, image 2 of 2
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
    Ask FixBot
  10. Cricut Maker Roller Bar Replacement: step 10, image 1 of 3 Cricut Maker Roller Bar Replacement: step 10, image 2 of 3 Cricut Maker Roller Bar Replacement: step 10, image 3 of 3
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
    Ask FixBot
  11. Cricut Maker Roller Bar Replacement: step 11, image 1 of 2 Cricut Maker Roller Bar Replacement: step 11, image 2 of 2
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
    Ask FixBot
  12. Cricut Maker Roller Bar Replacement: step 12, image 1 of 2 Cricut Maker Roller Bar Replacement: step 12, image 2 of 2
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
    Ask FixBot
  13. Cricut Maker Roller Bar Replacement: step 13, image 1 of 3 Cricut Maker Roller Bar Replacement: step 13, image 2 of 3 Cricut Maker Roller Bar Replacement: step 13, image 3 of 3
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
    Ask FixBot
  14. Cricut Maker Roller Bar Replacement: step 14, image 1 of 3 Cricut Maker Roller Bar Replacement: step 14, image 2 of 3 Cricut Maker Roller Bar Replacement: step 14, image 3 of 3
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
    Ask FixBot
  15. Cricut Maker Roller Bar Replacement, Motor: step 15, image 1 of 2 Cricut Maker Roller Bar Replacement, Motor: step 15, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
    Ask FixBot
  16. Cricut Maker Roller Bar Replacement: step 16, image 1 of 1
    • Remove the motor by pulling it from the device.
    Ask FixBot
  17. Cricut Maker Roller Bar Replacement: step 17, image 1 of 1
    • Under the motor there is a white plastic gear. To remove it, gently pull it off the axle.
    Ask FixBot
  18. Cricut Maker Roller Bar Replacement: step 18, image 1 of 2 Cricut Maker Roller Bar Replacement: step 18, image 2 of 2
    • Remove the washer from the top screw above the motor.
    • We found it was easier done by hand.
    Ask FixBot
  19. Cricut Maker Roller Bar Replacement: step 19, image 1 of 2 Cricut Maker Roller Bar Replacement: step 19, image 2 of 2
    • Remove the two 5 mm screws from the remaining motor on the opposite side, using a Phillips #2 screwdriver.
    Ask FixBot
  20. Cricut Maker Roller Bar Replacement: step 20, image 1 of 2 Cricut Maker Roller Bar Replacement: step 20, image 2 of 2
    • Twist and remove the motor from the machine.
    • Avoid touching the various tach disks on these motors.
    Ask FixBot
  21. Cricut Maker Roller Bar Replacement, Belt: step 21, image 1 of 3 Cricut Maker Roller Bar Replacement, Belt: step 21, image 2 of 3 Cricut Maker Roller Bar Replacement, Belt: step 21, image 3 of 3
    • Remove the two 10 mm screws using a Phillips #2 screwdriver.
    Ask FixBot
  22. Cricut Maker Roller Bar Replacement: step 22, image 1 of 2 Cricut Maker Roller Bar Replacement: step 22, image 2 of 2
    • Pull the belt holder towards you, and twist it sideways to slide it neatly into the same hole the belt is emerging from.
    Ask FixBot
  23. Cricut Maker Roller Bar Replacement: step 23, image 1 of 2 Cricut Maker Roller Bar Replacement: step 23, image 2 of 2
    • Pull the bar containing the axel and metal attachment out to remove them.
    • This should free the remaining side of the belt.
    Ask FixBot
  24. Cricut Maker Roller Bar Replacement: step 24, image 1 of 2 Cricut Maker Roller Bar Replacement: step 24, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the board on the main motor.
    Ask FixBot
  25. Cricut Maker Roller Bar Replacement: step 25, image 1 of 3 Cricut Maker Roller Bar Replacement: step 25, image 2 of 3 Cricut Maker Roller Bar Replacement: step 25, image 3 of 3
    • Remove the electrical tape from the connecting cable on the backside of the main motor.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Pull the cable out.
    Ask FixBot
  26. Cricut Maker Roller Bar Replacement: step 26, image 1 of 3 Cricut Maker Roller Bar Replacement: step 26, image 2 of 3 Cricut Maker Roller Bar Replacement: step 26, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 7 mm screws from the belt holder under the main motor.
    • Removing these two screws will cause the belt holder to detach.
    • Slip it through the hole in the main motor frame.
    Ask FixBot
  27. Cricut Maker Roller Bar Replacement: step 27, image 1 of 2 Cricut Maker Roller Bar Replacement: step 27, image 2 of 2
    • Remove the washer (e-clip) securing the bar to the belt holder.
    • We found it is easiest to remove by hand.
    • To remove it, simply twist and pull upwards to free it.
    • Remove the bar from the belt holder and then remove the belt holder.
    • Slip the belt out of the machine.
    Ask FixBot
  28. Cricut Maker Roller Bar Replacement, Roller Bar Replacement: step 28, image 1 of 2 Cricut Maker Roller Bar Replacement, Roller Bar Replacement: step 28, image 2 of 2
    • Pull the bar to the right of the machine, to free it from its placement.
    Ask FixBot
  29. Cricut Maker Roller Bar Replacement: step 29, image 1 of 1
    • Slide the roller bar out to remove it from the machine.
    Ask FixBot
4 other people completed this guide.
Devyn White
1,161 Reputation
5 Guides authored
4 Guide Comments
I think there's a step missing between step 4 and 5. Took the lid off in 4 and in 5 we can already see the motor...
Jamie French - Reply Share
For Step #4, for some models, there's 7 silver screws you'll need to remove. You'll need a #1 driver to take them out from the ceiling of the cutting area. That allowed me to take the lid off.
A Regis - Reply Share
Do you have aline the gears when you put it back together that are on the left side for the small roller ?
Tim Norvill - Reply Share
Someone can tell me where we can get this gear?
Rachel Cadot - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 213
All Time: 22,932
