Cricut Maker Front Door Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
95
All Time:
3,357
Comments: 12
12 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Follow this guide if you need to replace the front door of your Cricut Maker or if you need to access other parts of the device that require the door to be removed. The front door of the Cricut Maker holds the closing magnets, which close the machine entirely, keeping debris out, and your machine spic and span.
The door cannot be removed without removing the lid first. That said, if your lid is not magnetizing to the door, or your door is broken and you would like to replace it yourself, this guide is for you.
To be safe, be sure to turn off the device and unplug it from the outlet prior to beginning this repair.
Tools
    1. Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: step 1, image 1 of 3 Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: step 1, image 2 of 3 Cricut Maker Front Door Replacement, Cricut Maker Lid Replacement: step 1, image 3 of 3
      • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
      • Applying too much pressure to this can break it as it is very fragile.
      • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
      • Remove the cover from the connecting joint and set it aside.
      Ask FixBot
    2. Cricut Maker Front Door Replacement: step 2, image 1 of 2 Cricut Maker Front Door Replacement: step 2, image 2 of 2
      • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
      Ask FixBot
    3. Cricut Maker Front Door Replacement: step 3, image 1 of 3 Cricut Maker Front Door Replacement: step 3, image 2 of 3 Cricut Maker Front Door Replacement: step 3, image 3 of 3
      • Turn the device around, so that the back is facing you.
      • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
      • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
      • These actions should reveal the cylindrical connectors.
      Ask FixBot
    4. Cricut Maker Front Door Replacement: step 4, image 1 of 1
      • Press down on the lid.
      • Push the lid outwards to free it from the jointed clasps.
      Ask FixBot
    1. Cricut Maker Front Door Replacement, Front Door Replacement: step 5, image 1 of 2 Cricut Maker Front Door Replacement, Front Door Replacement: step 5, image 2 of 2
      • Using your hands or an opening tool, remove the four foot pads covering four screws.
      • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
      Ask FixBot
    2. Cricut Maker Front Door Replacement: step 6, image 1 of 3 Cricut Maker Front Door Replacement: step 6, image 2 of 3 Cricut Maker Front Door Replacement: step 6, image 3 of 3
      • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
      • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
      • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
      Ask FixBot
    3. Cricut Maker Front Door Replacement: step 7, image 1 of 3 Cricut Maker Front Door Replacement: step 7, image 2 of 3 Cricut Maker Front Door Replacement: step 7, image 3 of 3
      • Turn the device on its side.
      • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
      Ask FixBot
    4. Cricut Maker Front Door Replacement: step 8, image 1 of 3 Cricut Maker Front Door Replacement: step 8, image 2 of 3 Cricut Maker Front Door Replacement: step 8, image 3 of 3
      • Lift the top case off of the base of the device.
      • After removing this cover, the internals of the device will be exposed.
      Ask FixBot
    5. Cricut Maker Front Door Replacement: step 9, image 1 of 2 Cricut Maker Front Door Replacement: step 9, image 2 of 2
      • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
      • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
      Ask FixBot
    6. Cricut Maker Front Door Replacement: step 10, image 1 of 3 Cricut Maker Front Door Replacement: step 10, image 2 of 3 Cricut Maker Front Door Replacement: step 10, image 3 of 3
      • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
      • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
      Ask FixBot
    7. Cricut Maker Front Door Replacement: step 11, image 1 of 2 Cricut Maker Front Door Replacement: step 11, image 2 of 2
      • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
      Ask FixBot
    8. Cricut Maker Front Door Replacement: step 12, image 1 of 2 Cricut Maker Front Door Replacement: step 12, image 2 of 2
      • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
      • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
      Ask FixBot
    9. Cricut Maker Front Door Replacement: step 13, image 1 of 3 Cricut Maker Front Door Replacement: step 13, image 2 of 3 Cricut Maker Front Door Replacement: step 13, image 3 of 3
      • Remove a total of seven 10 mm screws from the underside of the door.
      • One side of the base has two 10mm screws.
      • The other side of the base has five 10 mm screws.
      Ask FixBot
    10. Cricut Maker Front Door Replacement: step 14, image 1 of 3 Cricut Maker Front Door Replacement: step 14, image 2 of 3 Cricut Maker Front Door Replacement: step 14, image 3 of 3
      • Pry the door from hinges using an iFixit opening tool.
      • Lift upwards and towards you, to remove the door from the hinges.
      Ask FixBot
Devyn White
1,182 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 95
All Time: 3,357
