Cricut Maker Belt Replacement
    1. Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: step 1, image 1 of 3 Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: step 1, image 2 of 3 Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: step 1, image 3 of 3
      • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
      • Applying too much pressure to this can break it as it is very fragile.
      • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
      • Remove the cover from the connecting joint and set it aside.
      Ask FixBot
    2. Cricut Maker Belt Replacement: step 2, image 1 of 2 Cricut Maker Belt Replacement: step 2, image 2 of 2
      • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
      Ask FixBot
    3. Cricut Maker Belt Replacement: step 3, image 1 of 3 Cricut Maker Belt Replacement: step 3, image 2 of 3 Cricut Maker Belt Replacement: step 3, image 3 of 3
      • Turn the device around, so that the back is facing you.
      • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
      • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
      • These actions should reveal the cylindrical connectors.
      Ask FixBot
    4. Cricut Maker Belt Replacement: step 4, image 1 of 1
      • Press down on the lid.
      • Push the lid outwards to free it from the jointed clasps.
      Ask FixBot
    1. Cricut Maker Belt Replacement, Front Door Replacement: step 5, image 1 of 2 Cricut Maker Belt Replacement, Front Door Replacement: step 5, image 2 of 2
      • Using your hands or an opening tool, remove the four foot pads covering four screws.
      • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
      Ask FixBot
    2. Cricut Maker Belt Replacement: step 6, image 1 of 3 Cricut Maker Belt Replacement: step 6, image 2 of 3 Cricut Maker Belt Replacement: step 6, image 3 of 3
      • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
      • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
      • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
      Ask FixBot
    3. Cricut Maker Belt Replacement: step 7, image 1 of 3 Cricut Maker Belt Replacement: step 7, image 2 of 3 Cricut Maker Belt Replacement: step 7, image 3 of 3
      • Turn the device on its side.
      • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
      Ask FixBot
    4. Cricut Maker Belt Replacement: step 8, image 1 of 3 Cricut Maker Belt Replacement: step 8, image 2 of 3 Cricut Maker Belt Replacement: step 8, image 3 of 3
      • Lift the top case off of the base of the device.
      • After removing this cover, the internals of the device will be exposed.
      Ask FixBot
    5. Cricut Maker Belt Replacement: step 9, image 1 of 2 Cricut Maker Belt Replacement: step 9, image 2 of 2
      • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
      • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
      Ask FixBot
    6. Cricut Maker Belt Replacement: step 10, image 1 of 3 Cricut Maker Belt Replacement: step 10, image 2 of 3 Cricut Maker Belt Replacement: step 10, image 3 of 3
      • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
      • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
      Ask FixBot
    7. Cricut Maker Belt Replacement: step 11, image 1 of 2 Cricut Maker Belt Replacement: step 11, image 2 of 2
      • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
      Ask FixBot
    8. Cricut Maker Belt Replacement: step 12, image 1 of 2 Cricut Maker Belt Replacement: step 12, image 2 of 2
      • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
      • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
      Ask FixBot
    9. Cricut Maker Belt Replacement: step 13, image 1 of 3 Cricut Maker Belt Replacement: step 13, image 2 of 3 Cricut Maker Belt Replacement: step 13, image 3 of 3
      • Remove a total of seven 10 mm screws from the underside of the door.
      • One side of the base has two 10mm screws.
      • The other side of the base has five 10 mm screws.
      Ask FixBot
    10. Cricut Maker Belt Replacement: step 14, image 1 of 3 Cricut Maker Belt Replacement: step 14, image 2 of 3 Cricut Maker Belt Replacement: step 14, image 3 of 3
      • Pry the door from hinges using an iFixit opening tool.
      • Lift upwards and towards you, to remove the door from the hinges.
      Ask FixBot
    1. Cricut Maker Belt Replacement, Motor: step 15, image 1 of 2 Cricut Maker Belt Replacement, Motor: step 15, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
      Ask FixBot
    2. Cricut Maker Belt Replacement: step 16, image 1 of 1
      • Remove the motor by pulling it from the device.
      Ask FixBot
    3. Cricut Maker Belt Replacement: step 17, image 1 of 1
      • Under the motor there is a white plastic gear. To remove it, gently pull it off the axle.
      Ask FixBot
    4. Cricut Maker Belt Replacement: step 18, image 1 of 2 Cricut Maker Belt Replacement: step 18, image 2 of 2
      • Remove the washer from the top screw above the motor.
      • We found it was easier done by hand.
      Ask FixBot
    5. Cricut Maker Belt Replacement: step 19, image 1 of 2 Cricut Maker Belt Replacement: step 19, image 2 of 2
      • Remove the two 5 mm screws from the remaining motor on the opposite side, using a Phillips #2 screwdriver.
      Ask FixBot
    6. Cricut Maker Belt Replacement: step 20, image 1 of 2 Cricut Maker Belt Replacement: step 20, image 2 of 2
      • Twist and remove the motor from the machine.
      • Avoid touching the various tach disks on these motors.
      Ask FixBot
    1. Cricut Maker Belt Replacement, Belt: step 21, image 1 of 3 Cricut Maker Belt Replacement, Belt: step 21, image 2 of 3 Cricut Maker Belt Replacement, Belt: step 21, image 3 of 3
      • Remove the two 10 mm screws using a Phillips #2 screwdriver.
      Ask FixBot
    2. Cricut Maker Belt Replacement: step 22, image 1 of 2 Cricut Maker Belt Replacement: step 22, image 2 of 2
      • Pull the belt holder towards you, and twist it sideways to slide it neatly into the same hole the belt is emerging from.
      Ask FixBot
    3. Cricut Maker Belt Replacement: step 23, image 1 of 2 Cricut Maker Belt Replacement: step 23, image 2 of 2
      • Pull the bar containing the axel and metal attachment out to remove them.
      • This should free the remaining side of the belt.
      Ask FixBot
    4. Cricut Maker Belt Replacement: step 24, image 1 of 2 Cricut Maker Belt Replacement: step 24, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the board on the main motor.
      Ask FixBot
    5. Cricut Maker Belt Replacement: step 25, image 1 of 3 Cricut Maker Belt Replacement: step 25, image 2 of 3 Cricut Maker Belt Replacement: step 25, image 3 of 3
      • Remove the electrical tape from the connecting cable on the backside of the main motor.
      • Use the tip of a spudger or your fingernail to flip up the small locking flap.
      • Pull the cable out.
      Ask FixBot
    6. Cricut Maker Belt Replacement: step 26, image 1 of 3 Cricut Maker Belt Replacement: step 26, image 2 of 3 Cricut Maker Belt Replacement: step 26, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 7 mm screws from the belt holder under the main motor.
      • Removing these two screws will cause the belt holder to detach.
      • Slip it through the hole in the main motor frame.
      Ask FixBot
    7. Cricut Maker Belt Replacement: step 27, image 1 of 2 Cricut Maker Belt Replacement: step 27, image 2 of 2
      • Remove the washer (e-clip) securing the bar to the belt holder.
      • We found it is easiest to remove by hand.
      • To remove it, simply twist and pull upwards to free it.
      • Remove the bar from the belt holder and then remove the belt holder.
      • Slip the belt out of the machine.
      Ask FixBot
4 other people completed this guide.
Devyn White
1,161 Reputation
5 Guides authored
4 Guide Comments
Where can I find the replace for the belt?
Adriahnna Sutton - Reply Share
Hi… Where can I buy the replace for the belt? In Amazon I find one with this description
GT2 Pitch: 2mm
Belt Height: 1.38mm
Tooth Height: 0.75mm
Material: Rubber
Width: 6mm
Can you confirm if it is similar to the original machine?
Kerilacle - Reply Share
Wie auch meine Vorredner, würde ich gerne wissen, ob du einen Link zu einem passenden Riemen bereitstellen kannst.
Beste Grüße
Martin Rathke - Reply Share
No answer on where to buy 😵‍💫😵‍💫😵‍💫
Tina Amburn - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 123
All Time: 10,175
