Cricut Maker 3 Top Cover Replacement
  1. Cricut Maker 3 Top Cover Replacement, Prepare your Cricut for disassembly: step 1, image 1 of 3 Cricut Maker 3 Top Cover Replacement, Prepare your Cricut for disassembly: step 1, image 2 of 3 Cricut Maker 3 Top Cover Replacement, Prepare your Cricut for disassembly: step 1, image 3 of 3
    • Be very careful not to cut yourself when working near the Cricut's small, sharp blade, located in the tool holder within the Cricut.
    • Power off the Cricut and unplug all cables.
    Ask FixBot
  2. Cricut Maker 3 Top Cover Replacement, Remove the rubber feet: step 2, image 1 of 3 Cricut Maker 3 Top Cover Replacement, Remove the rubber feet: step 2, image 2 of 3 Cricut Maker 3 Top Cover Replacement, Remove the rubber feet: step 2, image 3 of 3
    • Flip the Cricut over so the bottom is facing up.
    • Use your finger to pry up and remove all four rubber feet from the bottom of the Cricut.
    Ask FixBot
  3. Cricut Maker 3 Top Cover Replacement, Remove the screws from the base: step 3, image 1 of 2 Cricut Maker 3 Top Cover Replacement, Remove the screws from the base: step 3, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a Phillips screwdriver to remove the four 41 mm‑long screws securing the top cover to the base. There's one screw under each foot.
    Ask FixBot
  4. Cricut Maker 3 Top Cover Replacement, Open the Cricut: step 4, image 1 of 2 Cricut Maker 3 Top Cover Replacement, Open the Cricut: step 4, image 2 of 2
    • Flip the Cricut over so the silver lid is facing up.
    • You may replace the rubber feet before flipping your Cricut to avoid damaging the Cricut or your work surface.
    • Open the Cricut by lifting the top silver lid. The front tray will also open.
    Ask FixBot
  5. Cricut Maker 3 Top Cover Replacement, Remove the screws from the metal track: step 5, image 1 of 3 Cricut Maker 3 Top Cover Replacement, Remove the screws from the metal track: step 5, image 2 of 3 Cricut Maker 3 Top Cover Replacement, Remove the screws from the metal track: step 5, image 3 of 3
    • Inside the Cricut are seven screws securing the top cover to the metal track that guides the tool holder. You can reach these screws by putting a screwdriver bit in a ratcheting socket wrench. If you're using iFixit bits, the smaller bits work with a 4‑mm socket and the larger bits work with a 1/4‑inch socket.
    • Remove the seven 9.8 mm‑long Phillips screws securing the top cover to the metal track.
    Ask FixBot
  6. Cricut Maker 3 Top Cover Replacement, Remove the lid hinge cover: step 6, image 1 of 2 Cricut Maker 3 Top Cover Replacement, Remove the lid hinge cover: step 6, image 2 of 2
    • The lid hinge cover is located at the base of the silver lid and is held in place by five pegs which are lightly glued in place.
    • Insert the flat end of a spudger between the right side of the lid hinge cover and the top cover.
    • If there's not enough space to insert a spudger, push the silver lid to the left.
    • Use the spudger to pry up the cover.
    • Firmly pry near the pegs to avoid cracking the cover.
    Ask FixBot
  7. Cricut Maker 3 Top Cover Replacement: step 7, image 1 of 3 Cricut Maker 3 Top Cover Replacement: step 7, image 2 of 3 Cricut Maker 3 Top Cover Replacement: step 7, image 3 of 3
    • Use the flat end of a spudger to pry up along the long edge of the lid hinge cover until the cover is free.
    Ask FixBot
  8. Cricut Maker 3 Top Cover Replacement: step 8, image 1 of 2 Cricut Maker 3 Top Cover Replacement: step 8, image 2 of 2
    • Lift and remove the lid hinge cover.
    Ask FixBot
  9. Cricut Maker 3 Top Cover Replacement, Remove the lid screws: step 9, image 1 of 1
    • Use a Torx T8 screwdriver to remove the four 10.2 mm‑long screws securing the lid to the hinge.
    Ask FixBot
  10. Cricut Maker 3 Top Cover Replacement, Remove the lid: step 10, image 1 of 2 Cricut Maker 3 Top Cover Replacement, Remove the lid: step 10, image 2 of 2
    • Use the flat end of spudger to pry the lid out of the hinge while lifting the lid.
    Ask FixBot
  11. Cricut Maker 3 Top Cover Replacement: step 11, image 1 of 2 Cricut Maker 3 Top Cover Replacement: step 11, image 2 of 2
    Ask FixBot
  12. Cricut Maker 3 Top Cover Replacement, Lift the top cover: step 12, image 1 of 2 Cricut Maker 3 Top Cover Replacement, Lift the top cover: step 12, image 2 of 2
    • There's still a cable connected to the inside of the top cover. Don't attempt to fully remove the top cover yet.
    • Lift the top cover up from the Cricut just until it comes free of the base.
    Ask FixBot
  13. Cricut Maker 3 Top Cover Replacement: step 13, image 1 of 3 Cricut Maker 3 Top Cover Replacement: step 13, image 2 of 3 Cricut Maker 3 Top Cover Replacement: step 13, image 3 of 3
    • Rotate the top cover to the right and prop it up so the right side of the cover is resting on your work surface.
    Ask FixBot
  14. Cricut Maker 3 Top Cover Replacement, Disconnect the button board: step 14, image 1 of 2 Cricut Maker 3 Top Cover Replacement, Disconnect the button board: step 14, image 2 of 2
    Ask FixBot
  15. Cricut Maker 3 Top Cover Replacement: step 15, image 1 of 2 Cricut Maker 3 Top Cover Replacement: step 15, image 2 of 2
    • Peel up the tape securing the button wires to the inside of the top cover.
    • During reassembly, if this tape isn't sticking well, replace it with a piece of electrical tape to make sure these wires don't get caught in the gears.
    Ask FixBot
  16. Cricut Maker 3 Top Cover Replacement, Remove the top cover: step 16, image 1 of 1
    • Lift and remove the top cover.
    Ask FixBot
2 other people completed this guide.
Spencer Pennington
26,232 Reputation
127 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
19,333 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 94
All Time: 1,849
