Cricut Explore 3 (CXPL203) disassembly
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
154
All Time:
249
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
Go to step 1 ↓
destruction free opening of the CXPL203.
Repaired at Repair Cafe Markgröningen on August 8th 2026
Tools
    1. Cricut Explore 3 (CXPL203) disassembly, Remove bottom screws: step 1, image 1 of 1
      • Remove rubber pads, there are screws underneath
      • Remove the 11 screws on the bottom. Picture shows the different lengths to their corresponding holes.
      Ask FixBot
    2. Cricut Explore 3 (CXPL203) disassembly, Remove flat cable cover: step 2, image 1 of 1
      • push tool sled into the right housing side. One of the tools needs to be lifted in order to push it over the limiter
      • Lift cable cover on the left and pull it out. This step requires some force.
      • Remove cover from device by pulling it towards you on the left, carefully pull the right side from behind the sled
      Ask FixBot
    3. Cricut Explore 3 (CXPL203) disassembly, Remove side covers: step 3, image 1 of 3 Cricut Explore 3 (CXPL203) disassembly, Remove side covers: step 3, image 2 of 3 Cricut Explore 3 (CXPL203) disassembly, Remove side covers: step 3, image 3 of 3
      • Unscrew the 6 marked Philips screws. Two of them are hidden behind the flat flex cable cover.
      • Side covers can now be removed. The right one has a cable that needs to be unplugged from the main board
      • Don't pull the cable sideways, this might bend some pins in the connector
      Ask FixBot
    4. Cricut Explore 3 (CXPL203) disassembly, Remove screws and connectors from mechanical unit: step 4, image 1 of 2 Cricut Explore 3 (CXPL203) disassembly, Remove screws and connectors from mechanical unit: step 4, image 2 of 2
      • Remove connectors and tapes from the wire harness. Repeat on the opposite side.
      • Undo the screws holding the mechanical unit to the bottom. Repeat on the opposite side.
      • Marked screw holds the grounding wire, don't forget during reassembly
      • Undo screw on the right side. Apart from the Philips drive, it also has a hex head and can be undone with a small spanner without needing to cut through the plastic.
      • DO NOT lift mechanical unit from the device, remove cables first in the following steps. Hazard of damaging the cables
      Ask FixBot
    5. Cricut Explore 3 (CXPL203) disassembly, Remove cables to mechanical unit: step 5, image 1 of 2 Cricut Explore 3 (CXPL203) disassembly, Remove cables to mechanical unit: step 5, image 2 of 2
      • Lift mechanical unit about a centimeter with a plastic object
      • Unlock ZIF socket, remove flat flex cable
      • Don't forget to lock socket during reassembly, e.g. using the spudger
      • Lift mechanical unit up further
      • Remove connectors for the sheet sensors, pay attention to connector colors during reassembly
      Ask FixBot
    6. Cricut Explore 3 (CXPL203) disassembly, Mainboard: step 6, image 1 of 1
      • Mainboard can now be removed by undoing the marked screws. Don't forget grounding harness during reassembly
      • The marked hole holds no screw
      Ask FixBot
Redo above steps in reverse.
Special thanks to these translators:
de en
100%
FricklerYeen is helping us fix the world! Want to contribute?
Start translating ›
FricklerYeen
299 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 154
All Time: 249
