Up to 20% off select tools
Creative Zen X-Fi LCD Screen Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
92
All Time:
2,397
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The LCD screen is an output component that displays information to the user.
    1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: step 1, image 1 of 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: step 1, image 2 of 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: step 1, image 3 of 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Ask FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: step 2, image 1 of 1
      • The black rubber button pad can be removed by simply picking it up.
      Ask FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: step 3, image 1 of 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Ask FixBot
    2. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: step 4, image 1 of 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Ask FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: step 5, image 1 of 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Ask FixBot
    2. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: step 6, image 1 of 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Ask FixBot
    3. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: step 7, image 1 of 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Ask FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: step 8, image 1 of 2 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: step 8, image 2 of 2
      • Lift the right edge of the motherboard off the back case.
      • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
      Ask FixBot
    1. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: step 9, image 1 of 2 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: step 9, image 2 of 2
      • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
      Ask FixBot
    2. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: step 10, image 1 of 1
      • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
      • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
      Ask FixBot
3 other people completed this guide.
Author
with
Westley Courchene
3,410 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 92
All Time: 2,397
