Up to 20% off select tools
Creative Zen Vision W Motherboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
88
All Time:
1,855
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide will show you how to access the motherboard and speaker on your device.
    1. Creative Zen Vision W Motherboard Replacement, Battery Removal: step 1, image 1 of 3 Creative Zen Vision W Motherboard Replacement, Battery Removal: step 1, image 2 of 3 Creative Zen Vision W Motherboard Replacement, Battery Removal: step 1, image 3 of 3
      • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
      Ask FixBot
    1. Creative Zen Vision W Motherboard Replacement, Front Cover: step 2, image 1 of 2 Creative Zen Vision W Motherboard Replacement, Front Cover: step 2, image 2 of 2
      • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
      Ask FixBot
    2. Creative Zen Vision W Motherboard Replacement: step 3, image 1 of 3 Creative Zen Vision W Motherboard Replacement: step 3, image 2 of 3 Creative Zen Vision W Motherboard Replacement: step 3, image 3 of 3
      • Run the spudger along the cover and pry.
      • Do this gently to preserve the screen
      • The button pad may fall off when the cover is removed.
      Ask FixBot
    1. Creative Zen Vision W Motherboard Replacement, LCD Screen: step 4, image 1 of 3 Creative Zen Vision W Motherboard Replacement, LCD Screen: step 4, image 2 of 3 Creative Zen Vision W Motherboard Replacement, LCD Screen: step 4, image 3 of 3
      • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
      • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
      Ask FixBot
    2. Creative Zen Vision W Motherboard Replacement: step 5, image 1 of 1
      • Put the screen face down so you can see where the ribbon cables are attached.
      • Remove the red sticker that covers the ribbon cable connections.
      Ask FixBot
    3. Creative Zen Vision W Motherboard Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
      Ask FixBot
    4. Creative Zen Vision W Motherboard Replacement: step 7, image 1 of 3 Creative Zen Vision W Motherboard Replacement: step 7, image 2 of 3 Creative Zen Vision W Motherboard Replacement: step 7, image 3 of 3
      • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
      • Remove the screen from the device.
      Ask FixBot
    1. Creative Zen Vision W Motherboard Replacement, Keypad: step 8, image 1 of 1
      • Peel the orange sticker off of the motherboard.
      Ask FixBot
    2. Creative Zen Vision W Motherboard Replacement: step 9, image 1 of 2 Creative Zen Vision W Motherboard Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Lift the keypad from the left side and use tweezers to slide it out to the left.
      Ask FixBot
    3. Creative Zen Vision W Motherboard Replacement: step 10, image 1 of 2 Creative Zen Vision W Motherboard Replacement: step 10, image 2 of 2
      • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
      • Remove the ribbon cable from the keypad.
      Ask FixBot
    1. Creative Zen Vision W Motherboard Replacement, Back Cover: step 11, image 1 of 1
      • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
      Ask FixBot
    2. Creative Zen Vision W Motherboard Replacement: step 12, image 1 of 2 Creative Zen Vision W Motherboard Replacement: step 12, image 2 of 2
      • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
      • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
      • Be careful, some of the screws are difficult to see and can be easily stripped.
      Ask FixBot
    3. Creative Zen Vision W Motherboard Replacement: step 13, image 1 of 3 Creative Zen Vision W Motherboard Replacement: step 13, image 2 of 3 Creative Zen Vision W Motherboard Replacement: step 13, image 3 of 3
      • Carefully pull the back cover off of the rest of the device.
      • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
      • The USB input cover on the bottom of the device may also fall off.
      Ask FixBot
    1. Creative Zen Vision W Motherboard Replacement, Hard Drive: step 14, image 1 of 2 Creative Zen Vision W Motherboard Replacement, Hard Drive: step 14, image 2 of 2
      • Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
      • Lift the metal cover off.
      Ask FixBot
    2. Creative Zen Vision W Motherboard Replacement: step 15, image 1 of 3 Creative Zen Vision W Motherboard Replacement: step 15, image 2 of 3 Creative Zen Vision W Motherboard Replacement: step 15, image 3 of 3
      • Lift the white and black ribbon connection off of the motherboard.
      • The hard drive can now be removed.
      Ask FixBot
    1. Creative Zen Vision W Motherboard Replacement, Motherboard: step 16, image 1 of 3 Creative Zen Vision W Motherboard Replacement, Motherboard: step 16, image 2 of 3 Creative Zen Vision W Motherboard Replacement, Motherboard: step 16, image 3 of 3
      • Remove 2 screws (3.5 mm) on the black compact flash input using a Phillips #0.
      Ask FixBot
    2. Creative Zen Vision W Motherboard Replacement: step 17, image 1 of 1
      • Use a small flat head screwdriver to bend the plastic tab holding the compact flash input in place.
      • The compact flash input should pop off easily, be careful not to break it.
      Ask FixBot
    3. Creative Zen Vision W Motherboard Replacement: step 18, image 1 of 1
      • Turn the device over so the side where the screen was is facing up.
      • Push on the motherboard lightly to separate it from the casing.
      Ask FixBot
    4. Creative Zen Vision W Motherboard Replacement: step 19, image 1 of 2 Creative Zen Vision W Motherboard Replacement: step 19, image 2 of 2
      • Turn the device over again and pull on the motherboard very lightly.
      • The speaker will be covered in a black glue and you must cut through this in order to remove the motherboard.
      Ask FixBot
    5. Creative Zen Vision W Motherboard Replacement: step 20, image 1 of 1
      • Turn the speaker on its side so it can fit through the casing and the motherboard can be removed.
      Ask FixBot
    6. Creative Zen Vision W Motherboard Replacement: step 21, image 1 of 2 Creative Zen Vision W Motherboard Replacement: step 21, image 2 of 2
      • You have now removed the motherboard.
      • Speaker
      Ask FixBot
2 other people completed this guide.
Author
with
Tim Wilson
143 Reputation
6 Guides authored
Cal Poly, Team 17-2, Regan Spring 2013 Member of Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Members
96 Guides authored
2 Guide Comments
does the creative vision W have a 44 pin hard disk connector on the main board same as creative vision m has?
leohobb - Reply Share
If the main board on vision w hard disk connector has 44 pins as vision m has but the vision w has a zif 40 pin ribbon in to the hard disk.it make me belive that it is possible to use a zif connector style hard disk on vision M to with the hard disk cable from vision w?Or does i miss something?i want to try to use a 1.8 hard disk with around 100 GB capacity on vision M if possible
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 88
All Time: 1,855
