Up to 20% off select tools
Creative Zen Vision W Front Cover Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
3
Past 30 Days:
11
All Time:
938
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
If your Creative Zen Vision W (model 70PF201000009) has a damaged front cover that needs to be replaced, follow this guide. The front cover for this device keeps the button pad and display in place while providing protection to other internal components.
In Step 2, use the original button pad with the replacement cover.
    1. Creative Zen Vision W Front Cover Replacement, Front Cover: step 1, image 1 of 2 Creative Zen Vision W Front Cover Replacement, Front Cover: step 1, image 2 of 2
      • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
      Ask FixBot
    2. Creative Zen Vision W Front Cover Replacement: step 2, image 1 of 3 Creative Zen Vision W Front Cover Replacement: step 2, image 2 of 3 Creative Zen Vision W Front Cover Replacement: step 2, image 3 of 3
      • Run the spudger along the cover and pry.
      • Do this gently to preserve the screen
      • The button pad may fall off when the cover is removed.
      Ask FixBot
Author
with
Gabriele Pregadio
1 Reputation
2 Guides authored
Cal Poly, Team 17-2, Regan Spring 2013 Member of Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Members
96 Guides authored
1 Guide Comment
Fantastic but does anyone know where I can get this part?
VegetaFlex4Fitness - Reply Share
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 938
