Creative Zen Vision M Hard-drive Replacement
    1. Creative Zen Vision M Hard-drive Replacement, Opening the top: step 1, image 1 of 2 Creative Zen Vision M Hard-drive Replacement, Opening the top: step 1, image 2 of 2
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws.
      • Do the same for the bottom plastic surrounding the bottom connector, as there are two screws under here as well.
      Ask FixBot
    2. Creative Zen Vision M Hard-drive Replacement, Opening the device: step 2, image 1 of 2 Creative Zen Vision M Hard-drive Replacement, Opening the device: step 2, image 2 of 2
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      Ask FixBot
    3. Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: step 3, image 1 of 3 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: step 3, image 2 of 3 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: step 3, image 3 of 3
      • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
      Ask FixBot
    4. Creative Zen Vision M Hard-drive Replacement, Disconnecting the hard drive: step 4, image 1 of 1
      • Pull black hard drive connector located at the top right.
      • Ensure, as demonstrated by the image, that the screen is safely removed first. There is an iFixit guide showing how to carefully pull apart the Creative Zen Vision M.
      Ask FixBot
    5. Creative Zen Vision M Hard-drive Replacement, Removing bumpers: step 5, image 1 of 1
      • Pull off blue bumpers and connect to new hard drive
      Ask FixBot
    6. Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: step 6, image 1 of 2 Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: step 6, image 2 of 2
      • Lift white flap on top of hard drive to disconnect hard drive connector.
      Ask FixBot
Kirstie G
491 Reputation
4 Guides authored
Texas Tech, Team 12-1, Bennett Fall 2016 Member of Texas Tech, Team 12-1, Bennett Fall 2016
TTU-BENNETT-F16S12G1
4 Members
48 Guides authored
3 Guide Comments
How do you get the firmware on the new hard drive?
Selvedge - Reply Share
Download the firmware software from: http://support.creative.com/Downloads/we...
(Select firmware).
Then:
Close all application windows that are currently running on your computer.
Connect your player to your computer.
Double-click the downloaded file and follow the instructions on the screen.
Regards.
Brendan Eager - Reply Share
I should also update the link provided. Here’s a slightly better link. Select “Zen Series” then your specific model. To flash the firmware on the new hard drive. Download the file into your local hard disk. Close all application windows that are currently running on your computer. Connect your player to your computer (with the included adapter and USB wire). Double-click the downloaded file and follow the instructions on the screen.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 67
All Time: 5,374
