Up to 20% off select tools
Creative Zen MicroPhoto Motherboard Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
96
All Time:
2,378
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to safely disassemble the Creative Zen MicroPhoto in order to replace the motherboard.
    1. Creative Zen MicroPhoto Motherboard Replacement, Sliding Off the Back Cover: step 1, image 1 of 1
      • Slide off the back cover to reveal the battery.
      Ask FixBot
    2. Creative Zen MicroPhoto Motherboard Replacement, Removing the Battery: step 2, image 1 of 1
      • Removal of the battery may require some force.
      • Beginning with the notch directly beneath the battery, use the plastic opening tool to loosen the battery.
      • Once the battery is free, remove it from the device.
      Ask FixBot
    3. Creative Zen MicroPhoto Motherboard Replacement, Separating the Front Cover: step 3, image 1 of 1
      • Turn over the device.
      • Use the plastic opening tool to separate the front and back covers.
      • Move the opening tool around the perimeter of the device until the front cover detaches.
      Ask FixBot
    4. Creative Zen MicroPhoto Motherboard Replacement, Removing the Front Cover/Keypad: step 4, image 1 of 1
      • Slowly detach the front cover from the rest of the device to reveal the interior.
      Ask FixBot
    5. Creative Zen MicroPhoto Motherboard Replacement, Disassembling the Internal Device: step 5, image 1 of 1
      • Insert the flat-head screwdriver into the notch on the bottom of the device. Pry the main board and screen from the outer shell of the device.
      Ask FixBot
    6. Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board and Screen from the Device: step 6, image 1 of 1
      • The power button will come loose upon removal of outer shell. When reassembling, align power button properly.
      • Remove the main board and screen from the outer shell.
      Ask FixBot
    7. Creative Zen MicroPhoto Motherboard Replacement, Taking off the Back Cover of the Main Board: step 7, image 1 of 2 Creative Zen MicroPhoto Motherboard Replacement, Taking off the Back Cover of the Main Board: step 7, image 2 of 2
      • No tools are needed. The prongs (pictured) will release easily to remove the back cover.
      • Carefully remove the back cover.
      Ask FixBot
    8. Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Screen: step 8, image 1 of 1
      • Be gentle when removing the main board. The main board is attached to the front panel of the device by wires.
      • Using the flat-head screwdriver, carefully pry open the prongs on the sides of the device, and remove the main board from the screen.
      Ask FixBot
    9. Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Device: step 9, image 1 of 3 Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Device: step 9, image 2 of 3 Creative Zen MicroPhoto Motherboard Replacement, Removing the Main Board from the Device: step 9, image 3 of 3
      • Do not damage the ribbon tab (pictured). It is vital to the device.
      • Push the ribbon tab (sticking out below the main screen) backward through the square hole to remove the main board of the device.
      • Once the wiring is removed from the front panel, release the hinge at the bottom of the device. To do so, gently pry underneath the clip (pictured) with a plastic opening tool. The clip will pop up, and the motherboard can be completely removed.
      Ask FixBot
Author
with
Elly
174 Reputation
1 Guide authored
Ohio State, Team 1-3, Buehl Fall 2014 Member of Ohio State, Team 1-3, Buehl Fall 2014
OSU-BUEHL-F14S1G3
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 96
All Time: 2,378
