Creative Nomad Jukebox Zen Display Screen Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
83
All Time:
1,029
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Hello! This guide will show you the steps to replace the damaged/cracked screen in your Creative Nomad Jukebox Zen Device and have you listening to your music again in no time! Please use caution when using the soldering tool.
Tools
    1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: step 1, image 1 of 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: step 1, image 2 of 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: step 1, image 3 of 3
      • Use a J0 screwdriver to remove the eight 3.5mm screws.
      Ask FixBot
    2. Creative Nomad Jukebox Zen Display Screen Replacement: step 2, image 1 of 3 Creative Nomad Jukebox Zen Display Screen Replacement: step 2, image 2 of 3 Creative Nomad Jukebox Zen Display Screen Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to open the top cover by carefully prying at each corner.
      Ask FixBot
    1. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: step 3, image 1 of 1
      • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
      Ask FixBot
    1. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: step 4, image 1 of 1
      • Using the plastic opening tool to pop the metal tab holding the battery in place.
      • By breaking the sticker, it could void your warranty
      Ask FixBot
    2. Creative Nomad Jukebox Zen Display Screen Replacement: step 5, image 1 of 2 Creative Nomad Jukebox Zen Display Screen Replacement: step 5, image 2 of 2
      • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
      Ask FixBot
    3. Creative Nomad Jukebox Zen Display Screen Replacement: step 6, image 1 of 2 Creative Nomad Jukebox Zen Display Screen Replacement: step 6, image 2 of 2
      • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
      • Using soldering gun with care as it becomes extremely hot and can cause burns.
      Ask FixBot
    4. Creative Nomad Jukebox Zen Display Screen Replacement: step 7, image 1 of 1
      • Using the spudger tool, gently pry up the corners of the display screen to remove it.
      Ask FixBot
Austin Shaw
104 Reputation
1 Guide authored
IUPUI, Team S4-G5, Baechle Spring 2017 Member of IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 83
All Time: 1,029
