Creative Nomad Jukebox Zen Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
120
All Time:
2,199
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Hello! If your battery is not holding charge this guide will show you the steps to replace the old battery in your Creative Nomad Jukebox Zen Device. Follow the steps in this guide and you will be listening to hours of your music again in no time! Please use caution when using the soldering tool.
Tools
    1. Creative Nomad Jukebox Zen Battery Replacement, Battery: step 1, image 1 of 3 Creative Nomad Jukebox Zen Battery Replacement, Battery: step 1, image 2 of 3 Creative Nomad Jukebox Zen Battery Replacement, Battery: step 1, image 3 of 3
      • Use a J0 screwdriver to remove the eight 3.5mm screws.
      Ask FixBot
    2. Creative Nomad Jukebox Zen Battery Replacement: step 2, image 1 of 2 Creative Nomad Jukebox Zen Battery Replacement: step 2, image 2 of 2
      • Use plastic opening tool to open top cover by carefully prying at each corner.
      Ask FixBot
    3. Creative Nomad Jukebox Zen Battery Replacement: step 3, image 1 of 1
      • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover.
      Ask FixBot
    4. Creative Nomad Jukebox Zen Battery Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to unclip the metal bracket holding the battery down.
      • When sticker is torn warranty is void.
      Ask FixBot
    5. Creative Nomad Jukebox Zen Battery Replacement: step 5, image 1 of 2 Creative Nomad Jukebox Zen Battery Replacement: step 5, image 2 of 2
      • Desolder both red and black wires coming from battery.
      • How To Solder and Desolder Connections Use soldering gun with care as it becomes extremely hot and can cause burns.
      • Make sure to solder the black and red wires back into the same locations.
      Ask FixBot
Eli Richter
305 Reputation
3 Guides authored
IUPUI, Team S4-G5, Baechle Spring 2017 Member of IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 120
All Time: 2,199
