Up to 20% off select tools
Creative Nomad II Lock/Unlock Switch Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
13
All Time:
2,253
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
    1. Creative Nomad II Lock/Unlock Switch Replacement, Battery: step 1, image 1 of 1
      • Using your thumb, slide down and remove the battery cover.
      Ask FixBot
    2. Creative Nomad II Lock/Unlock Switch Replacement: step 2, image 1 of 1
      • Using your index finger, remove the old AA battery.
      • Install the new AA battery.
      Ask FixBot
    1. Creative Nomad II Lock/Unlock Switch Replacement, Smart Media Card: step 3, image 1 of 1
      • Slide down the eject button.
      • Pull out the old SmartMedia Card.
      • Insert the new SmartMedia Card.
      • The notched corner of the SmartMedia card should go in the top left corner.
      Ask FixBot
    1. Creative Nomad II Lock/Unlock Switch Replacement, Back Cover: step 4, image 1 of 1
      • Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
      Ask FixBot
    2. Creative Nomad II Lock/Unlock Switch Replacement: step 5, image 1 of 1
      • Lift the back cover off of the NOMAD II.
      • Remove the rubber USB port cover, the connected buttons along the left edge, and the plastic lock/unlock button on the upper right edge of the device.
      Ask FixBot
    3. Creative Nomad II Lock/Unlock Switch Replacement, Battery Compartment: step 6, image 1 of 1
      • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
      Ask FixBot
    4. Creative Nomad II Lock/Unlock Switch Replacement: step 7, image 1 of 1
      • Carefully remove the battery compartment.
      Ask FixBot
    5. Creative Nomad II Lock/Unlock Switch Replacement, Circuit Boards: step 8, image 1 of 1
      • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
      Ask FixBot
    6. Creative Nomad II Lock/Unlock Switch Replacement: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
      Ask FixBot
    7. Creative Nomad II Lock/Unlock Switch Replacement: step 10, image 1 of 1
      • Pull the circuit boards out of the back cover.
      • During reinstallation, firmly press the top of the circuit boards into the cover until you hear a click.
      Ask FixBot
    8. Creative Nomad II Lock/Unlock Switch Replacement: step 11, image 1 of 1
      • Gently pry the circuit boards apart.
      • This must be done with the USB port facing up, as shown.
      Ask FixBot
    9. Creative Nomad II Lock/Unlock Switch Replacement, Lock/Unlock Switch: step 12, image 1 of 1
      • Desolder the seven solder joints which hold the lock switch in place.
      • Install the new lock/unlock switch.
      Ask FixBot
Author
with
Craig Fischer
21 Reputation
2 Guides authored
Cal Poly, Team 9-2, Regan Winter 2012 Member of Cal Poly, Team 9-2, Regan Winter 2012
CPSU-REGAN-W12S9G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 2,253
