Creative Nomad II Headphone Jack Replacement
  1. Creative Nomad II Headphone Jack Replacement, Battery: step 1, image 1 of 1
    • Using your thumb, slide down and remove the battery cover.
    Ask FixBot
  2. Creative Nomad II Headphone Jack Replacement: step 2, image 1 of 1
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
    Ask FixBot
  3. Creative Nomad II Headphone Jack Replacement, Smart Media Card: step 3, image 1 of 1
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
    Ask FixBot
  4. Creative Nomad II Headphone Jack Replacement, Back Cover: step 4, image 1 of 1
    • Using a Phillips #00 Screwdriver, remove the two 7.5 mm screws located on the left and right side of the back cover, respectively.
    Ask FixBot
  5. Creative Nomad II Headphone Jack Replacement: step 5, image 1 of 1
    • Remove the back cover of the Nomad II.
    • Remove the following items located on the left and right side of the device:
    • The rubber USB port cover
    • The plastic lock/unlock switch cover
    • The buttons located on the left side of the device
    Ask FixBot
  6. Creative Nomad II Headphone Jack Replacement, Battery Compartment: step 6, image 1 of 1
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located in the bottom corners of the battery compartment.
    Ask FixBot
  7. Creative Nomad II Headphone Jack Replacement: step 7, image 1 of 1
    • Using your fingers, carefully remove the battery compartment.
    Ask FixBot
  8. Creative Nomad II Headphone Jack Replacement, Circuit Boards: step 8, image 1 of 1
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located on the left and right edges of the circuit board.
    Ask FixBot
  9. Creative Nomad II Headphone Jack Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers, carefully remove the metal loop attached to the circuit board from its plastic case on the left side of the battery compartment.
    Ask FixBot
  10. Creative Nomad II Headphone Jack Replacement: step 10, image 1 of 1
    • Pull out the circuit boards.
    • When reinserting the circuit boards, press the front face of the boards into the device case until you hear a click.
    Ask FixBot
  11. Creative Nomad II Headphone Jack Replacement: step 11, image 1 of 1
    • Position the circuit boards with the USB port facing up.
    • Gently separate the circuit boards.
    Ask FixBot
  12. Creative Nomad II Headphone Jack Replacement, Headphone Jack: step 12, image 1 of 1
    • Using a pair of tweezers, gently lift and peel back the thin copper film covering the headphone jack.
    • Only peel back the film enough to expose the headphone jack.
    • Completely removing the copper film can damage the device.
    Ask FixBot
  13. Creative Nomad II Headphone Jack Replacement: step 13, image 1 of 1
    • Gently remove the black adhesive tape from the underside of the headphone jack.
    Ask FixBot
  14. Creative Nomad II Headphone Jack Replacement: step 14, image 1 of 1
    • Desolder the four solder joints securing the headphone jack.
    • Remove the old headphone jack.
    • Install the new headphone jack.
    Ask FixBot
Craig Fischer
21 Reputation
2 Guides authored
Cal Poly, Team 9-2, Regan Winter 2012 Member of Cal Poly, Team 9-2, Regan Winter 2012
CPSU-REGAN-W12S9G2
5 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 1,853
