Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Disconnect all inputs and outputs.
The speaker cover is secured on each corner by a stud that is easily loosened by exerting some force by hand or using a flant, blunt object. Try not to damage the cloth.
Clean using a vacuum cleaner on the lowest setting.
Clean the conus of the speaker with a soft brush.
Remove the screw on 4 corners of the speaker.
Gently lift the speaker from the box
Remove 6 screws (large arrows) using a philips PZ1 screw driver.
Remove the remaining 3 small screws. This will be needed in the next step.
Pry loose the backplane from the box using a flat scewdriver or blunt knife, going from side to side.
2 other people completed this guide.
